Posted 23 September 2022, 4:24 pm EST
I have an embedded report designer where each datasource is set as an embedded datasource with “jsondata=” in the Connection.
This is working fine, and I can dynamically set the static JSON for each datasource and use it in the report.
However I’m struggling to get report parameters to work as a filter over the JSON data.
I can define, for instance, a string parameter, and then use it in filter clause with a like - “.*” operator. However this input parameter is not presented when the report is run,
If I state that the parameter can be empty / null, no parameters icon appears in the left menu on the report.
If I change things so that the parameter cannot be empty / null, the parameters icon appears, but no prompt for the parameter or entry field is displayed, the space where this should be is blank.
Do you have an example of a report with embedded JSON that uses a parameter value as a filter so I could check to see what I’ve missed?
Sean
