Posted 15 March 2021, 3:54 pm EST
I am having difficulty filtering a table by date parameters. The attached report made in the standalone report designer has two parameters: a start date and an end date. I would like to filter the table by the [Date] field for records that fall between these dates.
I have added a filter expression that I believe should work but it returns no records. If you remove the filter expression on the table you can see there is sample data for 1/25/21. Parameter date ranges that include 1/25/21 should show results, but aren’t.
Can you assist me in determining what is wrong it please?
TimecardStatusReport - Sample.zipTimecardStatusReport - Sample.zip
