How set the default folder for when the user clicks File in the Webdesigner
Posted by: mrisher on 30 August 2021, 2:00 pm EST
    Posted 30 August 2021, 2:00 pm EST
    Is there a way to set the default folder that the user can pull reports from?
    Requirement:
    Each user will log in with a company name and an employeeID. The file structure must look the same.
    In the resources folder I have that set up. Ex. resources\Company\Employee1002. In this folder are a bunch of rdlx files with preset datasets. When the user clicks File in the client side Webdesigner, this needs to be the default folder they see/save to. I thought I saw a ReportsFolder property on the JSViewer, but I cannot get this to work.
  • Posted 31 August 2021, 4:47 am EST
    It seems to me that you are using ActiveReports.NET, is that right?
  • Posted 31 August 2021, 7:35 am EST
    We are using MVC on the back end and the webdesigner on the front end, which I believe is jsviewer.
  • Posted 31 August 2021, 7:39 am EST
    thanks for sending the clarification.
    it seems that you are using ActiveReports.NET, but this forum is for ActiveReportsJS.
    You can send your question to the ActiveReports.NET forum which is available at https://www.grapecity.com/forums/ar-dev
