I want to hide the datasource
Posted by: ducn on 25 February 2021, 12:01 am EST
    Posted 25 February 2021, 12:01 am EST
    Hi team,
    https://www.grapecity.com/activereportsjs/api/modules/reportdesigner.html#datasourcetemplate
    How can I set canEdit = false for the datasource?
    Do u have any example?
  • Posted 25 February 2021, 5:21 am EST
    Hello, Duc,
    Please take a look at the example of the pre-defined resources setup that you can find at https://www.grapecity.com/activereportsjs/demos/features/designer-resources/purejs
  • Posted 25 February 2021, 10:19 pm EST
    Hi as case :
    • I load the report by file: designer.setReport({id:url})
    • After loading the report, I want to hide the icon add and edit for ( datasource, dataset). Can reportjs support it?
    Duc Nguyen
  • Posted 26 February 2021, 7:29 am EST
    Duc,
    There is no API that would allow you to hide the data panel, but I can offer you the brute-force solution. The data panel is just an HTML element, so you could hide by setting the CSS rules:
    .ar-data-panel .panel-group .panel:nth-child(1),
    .ar-data-panel .panel-group .panel:nth-child(2){
      display: none;
    I posted the example in the code sandbox:
    https://codesandbox.io/s/hide-data-panel-njj8w?file=/src/App.js
    However, this is a short-term solution because we could change the UI structure in future versions and the CSS rules need to be modified accordingly.
    Do I understand correctly that you want to hide data binding details from the end-user? This is a valid scenario, so we should look at how we could bring this feature into the product.
