Lookup Function does not work
Posted by: didem.kahyaoglu on 24 May 2023, 7:50 am EST
    Posted 24 May 2023, 7:50 am EST - Updated 24 May 2023, 7:51 am EST
    My data is nested. Here is some part of my data ;
        "_id": {
          "$oid": "639714f6dc06372526070821"
        "Run": {
          "Date": {
            "$date": "2022-12-12T11:48:06Z"
          "Index": 1,
          "Scenario": {
            "Name": "YZU_senaryo1",
            "Database": "default"
          "Svn": {
            "Address": "",
            "Revision": 0
        "Statistics": {
          "Platforms": [
              "Profile": "F-16C",
              "Type": "Wing",
              "Force": "Blue",
              "Total": 1,
              "Wrecked": 0,
              "Destroyed": 0
              "Profile": "F-16C_1",
              "Type": "Wing",
              "Force": "Blue",
              "Total": 1,
              "Wrecked": 0,
              "Destroyed": 0
              "Profile": "Oliver Hazard Perry Class_1",
              "Type": "Surface",
              "Force": "Red",
              "Total": 1,
              "Wrecked": 0,
              "Destroyed": 0
          "Weapons": [
              "Profile": "SOM-J",
              "Type": "MissileTracking",
              "Force": "Blue",
              "Total": 2,
              "Hit": 0,
              "Missed": 2
              "Profile": "RIM-66CSM-1",
              "Force": "Red",
              "Total": 2,
              "Hit": 2,
              "Missed": 0
        "Variables": [
            "Name": "V_0",
            "Type": "PlatformRelativeBearing",
            "Configuration": "InitialValue: 0 Increment: 30 FinalValue: 330 AnchorPlatformName[Destroyer] PlatformName[Fighter_1]",
            "Vaue": 0,
            "index" : 0
            "Name": "V_1",
            "Configuration": "InitialValue: 30 Increment: 30 FinalValue: 360 AnchorPlatformName[Destroyer] PlatformName[Fighter_2]",
            "Vaue": 30,
            "index" : 0
            "Name": "V_2",
            "Type": "PlatformRelativeDistance",
            "Configuration": "InitialValue: 50000 Increment: 50000 FinalValue: 100000 AnchorPlatformName[Destroyer] PlatformName[Fighter_1]",
            "Vaue": 50000,
            "index" : 0
            "Name": "V_3",
            "Configuration": "InitialValue: 50000 Increment: 50000 FinalValue: 100000 AnchorPlatformName[Destroyer] PlatformName[Fighter_2]",
            "Vaue": 50000,
            "index" : 0
            "Name": "V_4",
            "Type": "WeaponRange",
            "Configuration": "InitialValue: 10000 Increment: 10000 FinalValue: 50000 WeaponName[RIM-66CSM-1] []",
            "Vaue": 50000,
            "index" : 0
            "Name": "V_5",
            "Type": "LoadedWeaponCount",
            "Configuration": "InitialValue: 1 Increment: 1 FinalValue: 4 PlatformName[F-16C] [SOM-J]",
            "Vaue": 1,
            "index" : 0
            "Name": "V_6",
            "Configuration": "InitialValue: 1 Increment: 1 FinalValue: 4 PlatformName[F-16C_1] [SOM-J]",
            "Vaue": 1,
            "index" : 0
        "Measurements": [
            "Name": "M_0",
            "Type": "WEAPON_LAUNCH",
            "Configuration": " [Entity:Destroyer] [Force:BLUE->TARGET:SOM-J]",
            "Value": 0,
            "Details": {},
            "index" : 0
            "Name": "M_1",
            "Configuration": " [Force:RED->WEAPON:RIM-66CSM-1] [Force:BLUE->TARGET:SOM-J]",
            "Value": 2,
            "Details": {
              "AverageRange": 24813.617910990804,
              "Range": [24880.192418916515, 24747.043403065098]
            "index" : 0
            "Name": "M_2",
            "Type": "WEAPON_HIT",
            "Configuration": " [Force:BLUE->WEAPON:SOM-J] [Entity:Destroyer]",
            "Value": 0,
            "Details": {},
            "index" : 0
            "Name": "M_3",
            "Type": "WEAPON_INTERCEPT",
            "Configuration": " [Force:BLUE->WEAPON:SOM-J] [Entity:Destroyer] [Force:RED->INTERCEPTOR:RIM-66CSM-1]",
            "Value": 2,
            "Details": {
              "AverageRange": 14375.244757238168,
              "Range": [14420.824708140452, 14329.664806335886]
            "index" : 0
            "Name": "M_4",
            "Type": "PLATFORM_DMG_PERCENT",
            "Configuration": " [Entity:Destroyer]",
            "Value": 0,
            "Details": {},
            "index" : 0
            "Name": "M_5",
            "Value": 2,
            "Details": {
              "AverageRange": 49913.82936430945,
              "Range": [50166.56130724897, 49661.09742136992]
            "index" : 0
            "Name": "M_6",
            "Type": "WEAPON_MISS",
            "Value": 0,
            "Details": {},
            "index" : 0
    I want to show my data on Line Chart. y-axis should be MeasurmentsValues of the object with MeasurementsNames M_1 and x-axis should be VariableValues of the object with VariableNames V_1. I used Lookup function like this ;
    {Lookup("M_1", MeasurementsName, MeasurementsValue, "test")}
    but it shows me only first MeasurementsValue not all.
    I have no clue as to why this is happening. I will be glad if you help
  • Posted 28 May 2023, 10:46 pm EST
    Hi Didem,
    If you want to show Measurements Values on Y-Axis and Variable Values on the X-Axis you can create two DataSets one for Measurements and one for Variables and bind your chart’s DataField to Measurements’s Values, and on the Category axis (X-axis) you can bind your chart using a Lookup such as
    {Lookup("V" + Name.Substring(1), Name, Vaue, "Variables")}
    This way your Y-Axis will hold the data for M_1, M_2, … and X-Axis will hold the date for corresponding V_1, V_2, …
    Please find attached a sample implementing the same.
    Please Note: This query has been posted on a public forum, if this contains critical or confidential data you may reach out to us and we can get the same removed from our forum. After which you may open a thread on our internal support portal for further discussion.
    Anand
    Chart.zip
