Rendering HTML
Posted by: noah on 8 June 2020, 9:23 am EST
    Posted 8 June 2020, 9:23 am EST
    Is there a way to render HTML passed in as a parameter in ActiveReportsJS? This is key to our solution working (using Vue.JS and a text editor to add notes).
    I dug around and saw that there use to be a SuperLabelField for the old C1Reports. Is this something available in ActiveReportsJS? Or is there another solution I can utilize?
  • Posted 9 June 2020, 1:03 am EST
    There is no way to achieve the same in the ActiveReportJS. However, you can use the ActiveReports Professional to your requirement. You can use the FormattedText control to show the HTML content:
    https://www.grapecity.com/activereports/docs/v14/online/formatted-text.html
    ActiveReports Professional has JSVIewer through which you can see the report in the vue.JS. However, you need .Net FW/.Net Core back end service as it not a completely client-side product.
    Please refer to the following link for more information:
    https://www.grapecity.com/activereports/docs/v14/online/js-viewer.html
    https://www.grapecity.com/activereports/docs/v14/online/overview.html
    If you need a completely client-side product, please let me know.
  • Posted 9 June 2020, 7:32 am EST
    Hi Mohit,
    Thanks for the response. Is there a way to convert a ActiveReportsJS file into one compatible with ActiveReports Professional?
    Also, when you state we can view the report in vue.JS, is there still a way to update the report in vue.JS based on parameters passed to the report?
    Furthermore, are there any plans to have ActiveReportsJS get the feature for viewing HTML content?
    Noah
  • Posted 10 June 2020, 6:02 am EST
    Sorry to mention that there is no way, you need to do it manually. However, the way of creating the report is the same in both products. You do not find any difficulties to create a report in ARP
    Yes, you can pass the value to report through JSViewer and it will render the report as per parameter value.
    Yes, we have a plan for this but currently, there is no ETA for this.
