Report Bursting to email
Posted by: damien.murray on 16 August 2023, 5:30 am EST
    Posted 16 August 2023, 5:30 am EST
    Is there a way to burst active reports saved as pdf to an inbox on a schedule?
    Thanks for your help
    Damien
  • Posted 17 August 2023, 4:08 am EST
    Hi Damien,
    To send an email from a JavaScript application with an attachment using SMTP, you will need a backend server to handle the email sending process. You cannot directly send emails from a frontend application due to security restrictions.
    You can export the PDF to a blob and send it back to a server to send emails.
    For exporting a report to PDF please refer to the following lines of code:
    import { Core,PdfExport } from "@grapecity/activereports";
    async function sendEmail(){
      let reportId='report.rdlx-json';
      const report = new Core.PageReport();
      await report.load(reportId);
      var document = await report.run()
      var result=await exportPdf(document);
      var blob=result.data;
      // Use this blob to send email
    async function exportPdf(document){
      const pdfSettings= {  info: {  title: "report"  } }
      const result = await PdfExport.exportDocument(document, pdfSettings);
      //result.download("report"); // use this to download PDF file
      return result.blob;
    For sending emails I would suggest you to use nodemailer.
    For more information, on exporting report to PDF please refer to the following pages of our documentation:
    Printing and exporting the report output
    Akshay
