Posted 7 May 2021, 3:19 am EST
I have an issue when trying to pull a report viewer or designer. Every time i use GetStatisPages or Props i get an error Unexpected token ‘export’. Even if the other code is the bear minimum. remove import { Viewer } from “@grapecity/activereports-react”; and it works.
