Unable to shrink fields space when fields are hidden
Posted by: hmihir on 13 October 2020, 5:25 am EST
    Posted 13 October 2020, 5:25 am EST
    Hi Mohit,
    In ActivereportsJs I am not able to shrink fields space when those fields are hidden.
    As per attached image report-design , STAT field space is getting shrinked but not of Diagnosis and Comments.
    In Stat field I have provided hidden expression that if there is no data of stat then it will become hidden and then it will shrink , that is working as expected.
    But in Diagnosis and comments its not happening , I have made those fields hidden to true and can shrink to true. But that space is acquired and not getting shrined. check screenshot report-design.png
    Attached report preview screenshots and report as well.
    In bonemarrow folder CaseMenuBoneMarrowReport is main report and other are sub-reports. run main report.
    Its urgent Mohit, Please help. Its critical in terms of deliverables.
    Mihir
    BoneMarrow.zip[img]https://gccontent.blob.core.windows.net/forum-uploads/file-1b739ddd-f47f-45fc-aec8-ce0197d5adb9.png[/img][img]https://gccontent.blob.core.windows.net/forum-uploads/file-ef7676ba-c72d-406d-aa0b-09a22e5fab21.png[/img]BoneMarrow.zip[img]https://gccontent.blob.core.windows.net/forum-uploads/file-42516096-c824-4349-8812-9744a13cf89a.png[/img][img]https://gccontent.blob.core.windows.net/forum-uploads/file-494934a3-b285-4046-a34f-d9d0ef828cf4.png[/img]
  • Posted 13 October 2020, 5:27 am EST
    Attachment uploaded twice , please ignore one copy.
  • Posted 14 October 2020, 12:01 am EST
    Can you set the height of the TextBoxes to almost zero and move the below control to above to decrease the spaces between the Textbox and CaseCorrectionSubReport. It will solve you problem about the space. As you have set the “CanGrow” to true, textboxes will increase their size according to the text in it.
  • Posted 14 October 2020, 7:12 am EST
    Can you please update report I attached ?
  • Posted 14 October 2020, 7:19 am EST
    Please refer to the modified report.
    MohitCaseMenuBoneMarrowReport_Modified.zip
  • Posted 14 October 2020, 7:27 am EST - Updated 3 October 2022, 8:16 am EST
    Still there is space coming. see attached image. Its preview.
  • Posted 15 October 2020, 1:57 am EST
    It is very hard to eliminate the space the between the controls. I have tried at my end after setting the control height to zero still it has some space in it as below control render on the defined location only with the respect to above the control. Please refer to attached modified report.
    CaseMenuBoneMarrowReport_Mod.zip
