Posted 5 May 2023, 1:03 pm EST
I’m using active reports designer 17.0.0.
When I create a designer, I get the following error:
[Report Only] Refused to evaluate a string as JavaScript because ‘unsafe-eval’ is not an allowed source of script in the following Content Security Policy directive: "script-src ‘self’ ’ at web-designer.js:2
I see there is a similar issue with the viewer to do with the printer button but this seems to be a separate issue.
Do you have any insight as to what could be causing the issue and if there is some way of getting rid of this error, aside from allowing unsafe-eval?
