Posted 10 October 2022, 1:01 am EST
I would like to develop an ActiveX control and as I don’t own visual studio I’m wondering whether I can use VisualC++ express edition on it’s own, or do I also need the Windows Platform SDK?
Forums Home / ComponentOne / ActiveX Edition
Posted by: 0_leads.dodder on 10 October 2022, 1:01 am EST
Posted 4 November 2022, 4:11 am EST
You don’t need Visual Studio to write an Active X control. An Active X control is simply a COM object that is registered in a specific way that implements IUnknown and IObjectSafety.
You don’t need to create a Visual Studio Active X project. You can just create a normal DLL, add the proper manifest and cab it using the CAB SDK tools.
You don’t have to use ATL to write an Active X control. In fact, you’re probably better off not using it until you understand how the OLE interfaces work in the IE extensibility model.
So yes, you’ll be just fine with Visual Studio Express.
EDIT:
You should start with Introduction to Active X Controls.
Here is the CAB SDK.
You should have no problem finding examples for basic ActiveX controls by searching google, etc.
Here is a sample manifest, called YOURCONTROL.inf. Obviously replace YOURCONTROL with whatever you call your guy, and generate your own GUID and version numbers. This is the minimum manifest you’ll need.
[version]
signature=“$CHICAGO$”
AdvancedINF=2.0
[Add.Code]
YOURCONTROL.dll=YOURCONTROL.dll
[YOURCONTROL.dll]
file-win32-x86=thiscab
clsid={11111111-2222-3333-4444-555555555555}
FileVersion=1,2,3,4567
RegisterServer=yes
You’ll need a standard .DEF file in your project that lists the required exported functions for COM and self-registration. DllGetClassObject is where COM will call you to get the class factory for your COM object. RegisterServer and UnregisterServer is where you should write your initial state to the registry (e.g. your COM object registration, etc).
EXPORTS
DllCanUnloadNow PRIVATE
DllGetClassObject PRIVATE
DllRegisterServer PRIVATE
DllUnregisterServer PRIVATE
You’ll need an IDL file too, so you can define your COM object’s dispinterface so it can be called from script, and so it can fire events to Javascript. Something like this:
import “oaidl.idl”;
import “ocidl.idl”;
#include “dispids.h” // ← define your DISPIDs here
uuid(<>),
version(1.0),
library YOURCONTROLLIBRARY
uuid(<>),
hidden
dispinterface DYOURCONTROLEvents
properties:
methods:
// Add outgoing events here.
[id(DISPID_SOME_EVENT)] void SomeEvent();
[ dual, uuid(<<generate your own guid here>>) ] interface IYOURCONTROL : IDispatch { // Add methods and properties here. [id(DISPID_SOMEMETHOD)] HRESULT SomeMethod([in] BSTR bstrFoo); } [ uuid(<<generate your own guid here>>) ] coclass YOURCONTROLCtl { [default] interface IYOURCONTROL; [source, default] dispinterface DYOURCONTROLEvents; }
And, finally, your DLL entry point should look something like this:
HINSTANCE g_hInstance;
LONG g_nDllRefs;
extern “C”
BOOL WINAPI DllMain(HINSTANCE hInstance, DWORD dwReason, LPVOID lpReserved) {
switch (dwReason) {
case DLL_PROCESS_ATTACH:
g_hInstance = hInstance;
g_nDllRefs = 0;
break;
case DLL_PROCESS_DETACH: break; } return true;
// Call this whenever you create your object to keep your DLL loaded.
void DllAddRef() {
InterlockedIncrement(&g_nDllRefs);
// Call this when your object is destroyed.
void DllRelease() {
InterlockedDecrement(&g_nDllRefs);
STDAPI DllCanUnloadNow() {
return (g_nDllRefs == 0 ? S_OK : S_FALSE);
// This is where you create your class factory. See the IClassFactory documentation on msdn.
STDAPI DllGetClassObject(REFCLSID rclsid, REFIID riid, LPVOID* ppv) {
HRESULT hr;
if (rclsid == CLSID_YOUROBJECTCtl) {
CYOUROBJECTFactory *pYOUROBJECTFactory = new CYOUROBJECTFactory;
if (pYOUROBJECTFactory == NULL) {
hr = E_OUTOFMEMORY;
} else {
hr = pYOUROBJECTFactory ->QueryInterface(riid, ppv);
} else {
hr = CLASS_E_CLASSNOTAVAILABLE;
return hr;
STDAPI DllRegisterServer() {
// Write your registry keys for registering your ActiveX COM Object here.
return S_OK;
STDAPI DllUnregisterServer() {
// Delete your registry keys here.
return S_OK;
