Posted 29 December 2017, 10:27 pm EST
Hello:
I am still using Visual Basic 6. Recently I manually modified original .frm file to convert TrueDBGridStd.TDBGridS to TrueDBGrid80.TDBGrid. TrueDBGridStd.TDBGridS is a very very old control, at least 20 years old. I added the lines from _ExtentX to end My program works fine with TrueDBGridStd.TDBGridS By after I manually modified my original .frm file, I have the running error of type mismatch for the following line. Set Col0 = frmMain!DataGrid(i).Columns(0) Col0 is defined as Column. Dim Col0 As Column, Col1 As Column, Col2 As Column I is 0 when error occurs and did check form frmMain and DataGrid(0) did exist. Can anyone give me a hint how to solve the error? Thanks! Qingyi Begin TrueDBGrid80.TDBGrid DataGrid Height = 4560 Index = 0 Left = 90 TabIndex = 87 Top = 90 Width = 8325 _ExtentX = 2566 _ExtentY = 1931 _LayoutType = 0 _RowHeight = -2147483647 _WasPersistedAsPixels= 0 Columns(0)._VlistStyle= 0 Columns(0)._MaxComboItems= 5 Columns(0).DataField= "" Columns(0)._PropDict= "_MaxComboItems,516,2;_VlistStyle,514,3" Columns(1)._VlistStyle= 0 Columns(1)._MaxComboItems= 5 Columns(1).DataField= "" Columns(1)._PropDict= "_MaxComboItems,516,2;_VlistStyle,514,3" Columns.Count = 2 Splits(0)._UserFlags= 0 Splits(0).RecordSelectorWidth= 979 Splits(0).DividerColor= 15790320 Splits(0).SpringMode= 0 'False Splits(0)._PropDict= "_ColumnProps,515,0;_UserFlags,518,3" Splits(0)._ColumnProps(0)= "Columns.Count=2" Splits(0)._ColumnProps(1)= "Column(0).Width=2725" Splits(0)._ColumnProps(2)= "Column(0).DividerColor=0" Splits(0)._ColumnProps(3)= "Column(0)._WidthInPix=2646" Splits(0)._ColumnProps(4)= "Column(0).Order=1" Splits(0)._ColumnProps(5)= "Column(1).Width=2725" Splits(0)._ColumnProps(6)= "Column(1).DividerColor=0" Splits(0)._ColumnProps(7)= "Column(1)._WidthInPix=2646" Splits(0)._ColumnProps(8)= "Column(1).Order=2" Splits.Count = 1 PrintInfos(0)._StateFlags= 0 PrintInfos(0).PageHeaderFont= "Size=8.25,Charset=0,Weight=400,Underline=0,Italic=0,Strikethrough=0,Name=MS Sans Serif" PrintInfos(0).PageFooterFont= "Size=8.25,Charset=0,Weight=400,Underline=0,Italic=0,Strikethrough=0,Name=MS Sans Serif" PrintInfos(0).PageHeaderHeight= 0 PrintInfos(0).PageFooterHeight= 0 PrintInfos.Count= 1 DefColWidth = 0 HeadLines = 1 FootLines = 1 MultipleLines = 0 CellTipsWidth = 0 DeadAreaBackColor= 15790320 RowDividerColor = 15790320 RowSubDividerColor= 15790320 DirectionAfterEnter= 1 DirectionAfterTab= 1 MaxRows = 250000 _PropDict = "_ExtentX,2003,3;_ExtentY,2004,3;_LayoutType,512,2;_RowHeight,16,3;_StyleDefs,513,0;_WasPersistedAsPixels,516,2" _StyleDefs(0) = "_StyleRoot:id=0,.parent=-1,.alignment=3,.valignment=0,.bgcolor=&H80000005&" _StyleDefs(1) = ":id=0,.fgcolor=&H80000008&,.wraptext=0,.locked=0,.transparentBmp=0" _StyleDefs(2) = ":id=0,.fgpicPosition=0,.bgpicMode=0,.appearance=0,.borderSize=0,.ellipsis=0" _StyleDefs(3) = ":id=0,.borderColor=&H80000005&,.borderType=0,.bold=0,.fontsize=825,.italic=0" _StyleDefs(4) = ":id=0,.underline=0,.strikethrough=0,.charset=0" _StyleDefs(5) = ":id=0,.fontname=MS Sans Serif" _StyleDefs(6) = "Style:id=1,.parent=0,.namedParent=33" _StyleDefs(7) = "CaptionStyle:id=4,.parent=2,.namedParent=37" _StyleDefs(8) = "HeadingStyle:id=2,.parent=1,.namedParent=34" _StyleDefs(9) = "FooterStyle:id=3,.parent=1,.namedParent=35" _StyleDefs(10) = "InactiveStyle:id=5,.parent=2,.bgcolor=&H8000000F&,.fgcolor=&H80000012&" _StyleDefs(11) = "SelectedStyle:id=6,.parent=1,.namedParent=36" _StyleDefs(12) = "EditorStyle:id=7,.parent=1" _StyleDefs(13) = "HighlightRowStyle:id=8,.parent=1,.namedParent=38" _StyleDefs(14) = "EvenRowStyle:id=9,.parent=1,.namedParent=39" _StyleDefs(15) = "OddRowStyle:id=10,.parent=1,.namedParent=40" _StyleDefs(16) = "RecordSelectorStyle:id=11,.parent=2,.namedParent=41" _StyleDefs(17) = "FilterBarStyle:id=12,.parent=1,.namedParent=42" _StyleDefs(18) = "Splits(0).Style:id=13,.parent=1" _StyleDefs(19) = "Splits(0).CaptionStyle:id=22,.parent=4" _StyleDefs(20) = "Splits(0).HeadingStyle:id=14,.parent=2" _StyleDefs(21) = "Splits(0).FooterStyle:id=15,.parent=3" _StyleDefs(22) = "Splits(0).InactiveStyle:id=16,.parent=5" _StyleDefs(23) = "Splits(0).SelectedStyle:id=18,.parent=6" _StyleDefs(24) = "Splits(0).EditorStyle:id=17,.parent=7" _StyleDefs(25) = "Splits(0).HighlightRowStyle:id=19,.parent=8" _StyleDefs(26) = "Splits(0).EvenRowStyle:id=20,.parent=9" _StyleDefs(27) = "Splits(0).OddRowStyle:id=21,.parent=10" _StyleDefs(28) = "Splits(0).RecordSelectorStyle:id=23,.parent=11" _StyleDefs(29) = "Splits(0).FilterBarStyle:id=24,.parent=12" _StyleDefs(30) = "Splits(0).Columns(0).Style:id=28,.parent=13" _StyleDefs(31) = "Splits(0).Columns(0).HeadingStyle:id=25,.parent=14" _StyleDefs(32) = "Splits(0).Columns(0).FooterStyle:id=26,.parent=15" _StyleDefs(33) = "Splits(0).Columns(0).EditorStyle:id=27,.parent=17" _StyleDefs(34) = "Splits(0).Columns(1).Style:id=32,.parent=13" _StyleDefs(35) = "Splits(0).Columns(1).HeadingStyle:id=29,.parent=14" _StyleDefs(36) = "Splits(0).Columns(1).FooterStyle:id=30,.parent=15" _StyleDefs(37) = "Splits(0).Columns(1).EditorStyle:id=31,.parent=17" _StyleDefs(38) = "Named:id=33:Normal" _StyleDefs(39) = ":id=33,.parent=0" _StyleDefs(40) = "Named:id=34:Heading" _StyleDefs(41) = ":id=34,.parent=33,.valignment=2,.bgcolor=&H8000000F&,.fgcolor=&H80000012&" _StyleDefs(42) = ":id=34,.wraptext=-1" _StyleDefs(43) = "Named:id=35:Footing" _StyleDefs(44) = ":id=35,.parent=33,.valignment=2,.bgcolor=&H8000000F&,.fgcolor=&H80000012&" _StyleDefs(45) = "Named:id=36:Selected" _StyleDefs(46) = ":id=36,.parent=33,.bgcolor=&H8000000D&,.fgcolor=&H8000000E&" _StyleDefs(47) = "Named:id=37:Caption" _StyleDefs(48) = ":id=37,.parent=34,.alignment=2" _StyleDefs(49) = "Named:id=38:HighlightRow" _StyleDefs(50) = ":id=38,.parent=33,.bgcolor=&H8000000D&,.fgcolor=&H8000000E&" _StyleDefs(51) = "Named:id=39:EvenRow" _StyleDefs(52) = ":id=39,.parent=33,.bgcolor=&HFFFF00&" _StyleDefs(53) = "Named:id=40:OddRow" _StyleDefs(54) = ":id=40,.parent=33" _StyleDefs(55) = "Named:id=41:RecordSelector" _StyleDefs(56) = ":id=41,.parent=34" _StyleDefs(57) = "Named:id=42:FilterBar" _StyleDefs(58) = ":id=42,.parent=33" End
