Form Controls vs. ActiveX Controls
Posted by: shepherdkaisk30 on 15 April 2021, 3:12 am EST
  • Posted 15 April 2021, 3:12 am EST
    Hello!
    I am designing a data entry form for a work project and have decided to use some form of controls to help reduce the amount of data entry points. It’s an expandable document, so I have discovered that hiding/unhiding rows can have some funky results with control forms. I found a work around for the short term, but with scaling it up would lead to a lot of seemingly unnecessary VBA code. After some digging around I found that ActiveX controls seem to have more power to format it the way I want, BUT people seem to agree that you shouldn’t use ActiveX controls unless necessary.
    My questions: what is the preferred way to approach using controls in your document?
    Is there any major reasons NOT to use ActiveX controls on a relatively small document?
    What is your favorite to use?
    Questions I can anticipate now: This will eventually export to some sort of database. Don’t know if that info is relative, but thought I would include it.
  • Posted 16 April 2021, 3:31 am EST
    Thank you my issue has been solved
  • Posted 26 January 2022, 11:45 pm EST
