Posted 27 May 2020, 6:51 pm EST
Goodnight.
how could I use the windows themes either win7 or win10 or any windows, so that the VsFlexGrid Activex can cope with the windows theme both the header and the rows. Currently only have for WinXp
Forums Home / ComponentOne / ActiveX Edition
Posted by: bflnegocios on 27 May 2020, 6:51 pm EST
Goodnight.
Posted 28 May 2020, 6:47 am EST
Have you tried using VSFlexGrid in Win 7 or Win 10 environments? Which Windows theme do you wish to use? Actually, the grid should reflect the color changes in accordance with the Windows themes and there should not occur any issues. Is there any problem that you face while trying to do so?
Note: The latest version of VSFlexGrid is supported with Win 10 environment.
Pragati
Posted 29 May 2020, 2:37 pm EST
Hello, I was referring to be able to use the windows themes without importing the versions.
I see that in the VbNet version. if there are various appearances that can be used, but in the activex, or is there a way to activate ?.
or will have some model or example to view.
Thank you so much
Posted 3 June 2020, 6:11 am EST
I am sorry but I am a little unsure about your requirement here. What do you want to refer by “I was referring to be able to use the windows themes without importing the versions”?
In case it is for confirming if the ActiveX control is themeable like its .Net equivalent, it is not.
Pragati
