vsFlex8N/U/L (32Bit) compatible with LargeAddressAware?
Posted by: support on 16 May 2020, 10:42 am EST
    Posted 16 May 2020, 10:42 am EST
    Is the current flexgrid8 N/L/U (32Bit) compatible with the “LargeAddressWare” (VB6) parameter?
    Thx
    Dieter
  • Posted 19 May 2020, 5:16 am EST
    Hi Dieter,
    I have asked the developer for the same (internal tracking ID: 436439) and will get back to you soon.
    Pragati
  • Posted 21 May 2020, 1:48 am EST
    Hi Dieter,
    As per the developer, all of the VSFlex8 OCXs use correctly defined pointers and do not substitute 32 bit signed longs instead, but we cannot guarantee it as we do not test LAA directly. However, the same code is also compiled for our 64 bit versions which have not had reports of pointer related issues, so the pointer definitions are likely correct and appropriately cast when used with offsets.
    While we do not specify the Large Address Aware bit in the DLL/OCX header, you can add set the bin with the editbin.exe program included with Microsoft Visual Studios > 6.0. This actiion will invalidate the ComponentOne/GrapeCity digital Authenticode signature, so if that is an issue, you should strip the signature and add your own if necessary.
    Pragati
  • Posted 21 May 2020, 2:50 am EST
    Thx, Pragati!
    :slight_smile:
    Greetings from germany
    Dieter
