Access Conversion
Posted by: ricewalker on 14 September 2017, 6:48 pm EST
    Posted 14 September 2017, 6:48 pm EST
    [activereports_archive]Looking at the documentation located at http://helpcentral.componentone.com/nethelp/AR7Help/OnlineEn/Converting%20with%20Import%20Wizard.html it appears that AR 7 can’t convert an MS Access 2010 report as the only supported versions are 97, 2000, 2002, 2003 or 2007. Is there any way to convert an MS Access 2010 report?
    Rick[/activereports_archive]
  • Posted 14 September 2017, 6:48 pm EST
    [activereports_archive]Hello Rick,
    Yes, according to the document AR7 does not support converting an MS Access 2010 report. Could you please send across one of your MS Access 2010 report so that I can try and convert it using the latest version of ActiveReports? If it still does not support, then this could be an enhancement for future ActiveReports versions.
    Abdias
  • Posted 30 September 2017, 6:32 pm EST
    I am looking to import Access97 reports - I have the trial version (latest)…
    Martin
  • Posted 3 October 2017, 3:06 am EST
    Hi Martin,
    Yes, you can import Access97 reports in the latest version of ActiveReports i.e v11 as is mentioned here - http://help.grapecity.com/activereports/webhelp/AR11/index.html#Converting%20with%20Import%20Wizard.html
