Posted 10 September 2021, 2:41 am EST
Hi, I’m very new to active reports and I’m trying to use dataset1 data to filter my dataset2 query. I have a Filter dialogue with a parameter to filter the data of dataset1, this works and shows just one line of data matching a part number and gives me on-off times that correspond with that part number. What I’m trying to achieve is from the part number result, use the on-off times (two separate date-time columns) to filter my dataset2 data between those times to show a graph. My Dataset2 has a lot more data as dataset1 is more of an index. I’ve tried to set parameters inside the dataset2 but this does not seem to work.
Does anyone have any advice if this can even be done in a single sheet.
Thanks in advance
