Active Reports 10 - Horizontal Line not showing on the top of column heading
Posted by: abhishek.mt on 3 January 2019, 3:47 am EST
    Posted 3 January 2019, 3:47 am EST
    We are using Active Reports 10 html viewer as our reporting tool.
    While viewing, Horizontal Line is not showing on the top of column heading.
    But while in exporting to PDF, there is showing the line.
    Please give me a solution.
  • Posted 3 January 2019, 4:13 am EST
    Could you please confirm the report type(RDL/Section/Page) that you are using? It is very helpful for us if you provide the running report so that I can replicate the issue at our end.
  • Posted 3 January 2019, 7:55 am EST
    We are using Section report type
  • Posted 3 January 2019, 8:30 am EST
    Diagonal Line control is not supported in HTML5viewer. Could you please set the “Y1” and “Y2” property of line control same.
  • Posted 4 January 2019, 12:36 am EST
    I did not mention diagonal line. I have mentioned about horizontal line. The actual problem is that, if Report subheading is there, then the horizontal line above the column headings will show. But, if there is no subheading, then the horizontal line will disappear.
  • Posted 7 January 2019, 4:46 am EST
    Could u please provide any solution for this issue?
  • Posted 8 January 2019, 3:15 am EST
    Sorry for the confusion and delay, I am out of the office for the past few days due to sickness.
    I have tried to reproduce the issue as per above information. However, I am not able to replicate the issue at my end. Please refer to the attached application.
    If the issue still exists, Could you please either modify the attached application or provide your own stripped down project so that I can try reproducing the same behavior at my end and assist you further accordingly?
    Steps:
    Run the attached sample
    Click on “RPX Report”
    Observe: Horizontal line has appeared on chrome
    HTML5 Viewer.zip
  • Posted 31 January 2019, 7:12 am EST
               The problem is not resolved yet. Still that issue is there in Active reports 10 HTML  Viewer using section reports
  • Posted 1 February 2019, 9:21 am EST
    Hello Abhishek,
    Could you please provide us the sample so that we can replicate the issue our end. This will be very helpful for us to resolve the problem asap.
