Active Reports 14 API - Dinamically set url as a value on a RDLX report
Posted by: ricardo.pereira on 18 September 2020, 12:28 pm EST
    Posted 18 September 2020, 12:28 pm EST
    Context:
    We have a rdlx report which has an image that gets generated through an api call like this:
    	<Image Name="Image1">
    		<DataElementName>Image1</DataElementName>
    		<Height>0.32cm</Height>
    		<Left>2.04895cm</Left>
    		<MIMEType>image/bmp</MIMEType>
    		<Sizing>Fit</Sizing>
    		<Source>External</Source>
    		<Value>[b]="http://localhost:5001/api/ReportImage/"[/b] &amp; Fields!Image1Data.Value</Value>
    		<Width>11.4992cm</Width>
    		<ZIndex>232</ZIndex>
    	</Image>
    This works fine locally because both the report and the api are on the same solution and running on http://localhost:5001.
    Problem:
    The problem we are facing is when we deploy the api and use a different url than “http://localhost:5001”. The call will still be made to “http://localhost:5001” which is obviously incorrect.
    Is there a way to dynamically set the URL so that we can change it per environment? I.e. One URL for staging and a completely different one for live.
    Ricardo Pereira
  • Posted 21 September 2020, 6:31 am EST
    We solved this issue by adding a “BaseUrl” property to the dataset that fed the report and then referencing it on the tag.
    I don’t know how to delete this post or mark it as “solved” I would appreciate if you could close it for me.
    Best regards,
    Ricardo Pereira
