Posted 9 June 2021, 5:12 pm EST
Oh and here’s the full text of the exception being thrown:
Tax and Assessment 2.1.10.0
Unexpected Error - Export Report from Viewer in Tax and Assessment 2.1.10.0
An unexpected error has occurred. Please retry the operation or contact MuniSoft Support for assistance.
System.TypeInitializationException
The type initializer for ‘GrapeCity.ActiveReports.Export.Excel.Internal.’ threw an exception.
This error occurred at GrapeCity.ActiveReports.Export.Excel.Internal.…ctor()
at GrapeCity.SpreadBuilder.Workbook.get_ExportHandler()
at GrapeCity.SpreadBuilder.Workbook.Save(String filePath)
at GrapeCity.ActiveReports.Export.Excel.Section.XlsExport.Export(SectionDocument document, String filePath, String pageRange)
at GrapeCity.ActiveReports.Export.Excel.Section.XlsExport.Export(SectionDocument document, String filePath)
at Reports.ReportViewer.Export_Button_Click(Object sender, EventArgs e) in C:\Version 2.1.10\Development\Reports\CM_Reports\Forms\ReportViewer.vb:line 364
System.IO.FileLoadException: Could not load file or assembly ‘DocumentFormat.OpenXml, Version=2.12.1.0, Culture=neutral, PublicKeyToken=8fb06cb64d019a17’ or one of its dependencies. The located assembly’s manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040)
File name: ‘DocumentFormat.OpenXml, Version=2.12.1.0, Culture=neutral, PublicKeyToken=8fb06cb64d019a17’
at GrapeCity.ActiveReports.Export.Excel.Internal.…cctor()
WRN: Assembly binding logging is turned OFF.
To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1.
Note: There is some performance penalty associated with assembly bind failure logging.
To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog].
