Active Reports 15 Web Desiger
Posted by: matt.norby on 3 May 2021, 9:47 am EST
  • Posted 3 May 2021, 9:47 am EST
    I am looking for more documentation or samples on the Web Designer for Active Reports 15. Here are some of the requirements that I need to meet for the project I am working on.
    General Project Requirements
    • “Multi-tenant application”
    • “SQL Server Database”
    • “.NET Core 3.1/5.0”
    • “Multiple web servers”
    • “IdentityServer for authentication”
    • "[/li]
    AR Web Designer Specifics
      [li]Reports must be saved in SQL Server"
    • “Templates must be saved in SQL Server”
    • “Images such as logos can come from a table in the database”
    • “Themes saved in the database”
    Where can I find detailed documentation for the web-designer.js file?
    How can I limit the providers in the Data Tab when a user adds a data source? i.e. only allow one or many of the providers listed.
    Is there a way to default the provider in the Data Tab when a user adds a data source to the JSON provider?
    For the Data Source if it can be defaulted to the JSON provider how can I disable the radio button group and set the JSON Data Type to External File or URL?
    For the JSON Document how can I disable the input so the user can not enter the URL and how can I set the input’s value programmatically?
    For the JSON Schema Type how can I disable the radio button group and set the value to Auto?
    How can I limit the file type of images uploaded by the user? How can I limit the size of the images uploaded by the user?
    Where can I find documentation to build custom themes?
    Where can I find documentation on how to enable/disable specific controls in the Web Designer?
    Web Designer ASP.NET Middleware
    Where can I find more details documentation on the middleware?
    How do I go about implementing UseDataProviders?
    Where can I find out more information on * “DataProviderInfo”
    array and its implementation?
    Where can I find out more information on * “UseCustomStore”
    Matt
  • Posted 10 May 2021, 11:29 pm EST
    Your question is replied in the following case:
    CAS-21823-Z6B7M6
    Please reply to CRM case only to avoid confusion.
