Active Reports in Docker
Posted by: davidg on 1 September 2019, 9:54 pm EST
    Posted 1 September 2019, 9:54 pm EST
    Has anyone tried to deploy a ASP.NET Framework application in a Docker container with Active Reports as part of the application?
    We have Active Reports 6 and Active Reports 9 reports in the ASP.NET application currently and having problems with licensing.
    Any help much appreciated.
  • Posted 2 September 2019, 1:30 am EST
    No, AR product is not tested in Docker environment. Also, AR9 was declared a legacy product now. It is out of maintenance mode now. Hence, we do not provide support for the same or no bug fixing will be done in the same. I would recommend you to use the latest version of ActiveReports i.e ActiveReports 13. Please refer to the following link for more information:
    https://www.grapecity.com/activereports
    However, you can try after licensing your web application through WebKeyGenerator utility. Please refer to the “To create the Web Key with the Web Key Generator utility” topic in the following documentation link:
    https://help.grapecity.com/activereports/webhelp/AR9/index.html#arHOWLicensingActiveReports.html
    https://help.grapecity.com/activereports/webhelp/Legacy/ActiveReports6/topic34.html
    Hope it helps.
