Active Reports v9 - 2 Column Report, Keep Group Together - First Detail
Posted by: jmalda on 19 October 2018, 8:06 am EST
    Posted 19 October 2018, 8:06 am EST - Updated 30 September 2022, 5:57 pm EST
    Hi everyone,
    We have created a 2 column report that is being used as a plant catalogue. The plants are grouped by Genus (Cryptomium, Dennistaedia, Dryopteris etc - see picture below). The group header’s GroupKeepTogether property is set to FirstDetail so that no headers are orphaned and being displayed on their own.
    The report looks great except for one small issue: it appears if there is a new Group starting at the bottom of the first column, and the first plant will not fit below the group header in column 1, the group header does not move with the first plant to the top of the second column. The group header remains on its own in the first column.
    Is this a bug, or unsupported functionality? Or perhaps I am missing a setting? Thanks for your help.
  • Posted 22 October 2018, 4:20 am EST
    This is the design behavior of the ActiveReport. Could you please check after setting the “GroupKeepTogether” to “All”, see if the outcome will meet your requirements.
  • Posted 22 October 2018, 1:13 pm EST
    Hi there,
    Thank you for your reply.
    Setting “GroupKeepTogether” to “All” doesn’t really solve the problem. If the group (and all its details) do not fit on the page in question, it starts on a completely new page. So for the example above, Dryopteris starts on the beginning of the next page. I.e. the entire column 2 is blank on the page above.
    Do you know if the functionality I am requesting is supported in later versions of ActiveReports?
  • Posted 23 October 2018, 6:14 am EST
    Currently, it is not possible even with the latest build of AR. However, I have escalated the case as the feature request to our development team(266176) and will inform you once I get any information from them.
  • Posted 24 October 2018, 1:16 am EST
    Sorry to mention that this is a limitation of AR. Also, there is no future plan to overcome this limitation.
    Again, sorry for the inconvenience caused.
