Posted 27 May 2020, 4:24 pm EST
I am pleased to announce the release of ActiveReports 13.3. This will be the final service pack for ActiveReports 13. As usual, this is a free update for existing AR13 users.
ActiveReports 13.3 Download: http://cdn.grapecity.com/ActiveReports/AR13/ActiveReports-v13.3.18800.0.msi
Below is a list of issues that were fixed in this service pack.
"272040 - When converting RPX to Page reports, some controls beyond of page bounds were removed "
"273739 - Report not found’ error shown when deploying a .NET Core MVC application on Virtual Directory "
"275345 - “LayoutException: The size of the subreport is too small” error after upgrading from AR12.0 to AR13 "
"275536 - “LocateDataSource” event fires twice in the JSViewer "
"275980 - Ruler not properly aligned with grid lines in report designer surface "
"276125 - Fixed issue when UseTopDirectoryOnly set to “False” in “UseFileStore” method of UseDesigner API "
"276230 - Custom button in HTMLViewer stopped working after Chrome V77 update "
"276572 - Picture.Image property can now be set to null to hide image "
"277254 - Stylesheets from a relative path is not applied in Visual Studio integrated designer "
"277538 - HTML5 Viewer Refresh method does not re-render report "
"277550 - Hyperlinks in HTML Export broken "
"277610 - RichTextBox duplicating data after migrating from AR11 to AR13 "
"277628 - Restricted domains did not unload when new domains were created "
"277981 - Error occurs when previewing a report referencing a subreport in subdirectory of resource file "
"278150 - Invalid JSON is generated if report contains values with quotes "
"278371 - Custom chart control causes a “DataSet name needs to be specified” error in report with multiple data sources "
"278739 - LocateDataSource Event does not fire when fields of dataset used in parameter "
"275182 - SvgImage CRI is corrupt in HTML export "
"275264 - PDF export truncates text at the bottom "
"275446 - Adding Line control by double clicking in RDL\Page toolbox uses different units of measurement "
"277608 - FormattedText control displays text with extra spaces "
