ActiveReports and ADA Compliance
Posted by: rkuehn on 4 November 2020, 11:44 am EST
    Posted 4 November 2020, 11:44 am EST
    Which versions of ActiveReports, if any, create PDFs that are ADA compliant?
  • Posted 5 November 2020, 12:23 am EST
    What I understood, from ADA compliant, you are referring to 508 PDF compliance. If my understanding is correct then AR11 + supports the 508 PDF compliance.
    You need to set the version property of PDF export to PDF/UA-1 to make a pdf 508 compliance.
    If there is any bug occurs, then it will be fixed only in the latest version of the AR.
  • Posted 10 November 2020, 7:54 pm EST
    https://www.grapecity.com/forums/ar-dev/activereports-and-ada-comp#hellowhat-i-understood-fro
    Mohit,
    Thanks for your response. Can you help me understand how setting that property in AR11+ makes the PDF generated by ActiveReports compliant? Or can you point me to resources explaining how that compliance is achieved?
    Thanks in advance for your help!
  • Posted 11 November 2020, 3:24 am EST
    You can use the following lines of code to make the generated PDF as 508 complaince.
    For SectionReport,
    // Create a Section report.
    GrapeCity.ActiveReports.SectionReport rpt = new GrapeCity.ActiveReports.SectionReport();
    // For the code to work, report.rpx must be placed in the bin\debug folder of your project.
    System.Xml.XmlTextReader xtr = new System.Xml.XmlTextReader(Application.StartupPath + "\\report.rpx");
    rpt.LoadLayout(xtr);
    rpt.Run();
    GrapeCity.ActiveReports.Document.SectionDocument MyDocument = new GrapeCity.ActiveReports.Document.SectionDocument("rpt");
    // Export the report in PDF format.
    GrapeCity.ActiveReports.Export.Pdf.Section.PdfExport PdfExport1 = new GrapeCity.ActiveReports.Export.Pdf.Section.PdfExport();
    PdfExport1.Version = GrapeCity.ActiveReports.Export.Pdf.Section.PdfVersion.PDFUA1;
    PdfExport1.Export(MyDocument, Application.StartupPath + "\\PDFExpt.pdf");
    For PageReport,
    // Provide the page report you want to render.
    System.IO.FileInfo rptPath = new System.IO.FileInfo(@"..\..\PageReport1.rdlx");
    GrapeCity.ActiveReports.PageReport pageReport = new GrapeCity.ActiveReports.PageReport(rptPath);
    // Create an output directory.
    System.IO.DirectoryInfo outputDirectory = new System.IO.DirectoryInfo(@"C:\MyPDF");
    outputDirectory.Create();
    // Provide settings for your rendering output.
    GrapeCity.ActiveReports.Export.Pdf.Page.Settings pdfSetting = new GrapeCity.ActiveReports.Export.Pdf.Page.Settings();
    // Set the rendering extension and render the report.
    GrapeCity.ActiveReports.Export.Pdf.Page.PdfRenderingExtension pdfRenderingExtension = new GrapeCity.ActiveReports.Export.Pdf.Page.PdfRenderingExtension();
    GrapeCity.ActiveReports.Rendering.IO.FileStreamProvider outputProvider = new GrapeCity.ActiveReports.Rendering.IO.FileStreamProvider(outputDirectory, System.IO.Path.GetFileNameWithoutExtension(outputDirectory.Name));
    // Overwrite output file if it already exists
    outputProvider.OverwriteOutputFile = true;
                pdfSetting.Version = GrapeCity.ActiveReports.Export.Pdf.Page.PdfVersion.PDFUA1;
    pageReport.Document.Render(pdfRenderingExtension, outputProvider, pdfSetting);
    Hope it helps.
