ActiveReports integration with Angular app
Posted by: rohini.jeughale on 19 April 2023, 5:49 am EST
    Posted 19 April 2023, 5:49 am EST
    We have an Angular project version 15 and supported by ASP.NET MVC backend.
    We need a direct communication to the DBs through the Report designer and hence thinking of using Activereports over activereportsJs(As direct DB connection is not supported) for our Angular project.
    As per the resources available, could not find any sample for integration with Normal angular project (not ASP.NET angular app).
    Is it possible to design the reports in ASP.NET project and view them in the angular application. (may be by using some AR server)
    Could you please help us with some samples or approach to integrate the AR with angular app.
    Thanks in Advance
  • Posted 21 April 2023, 3:26 am EST
    Hi Rohini,
    This seems like a duplicate case for your Case ID: CAS-39766-B2N1H6. We have updated the solution there you may refer to the same!
    Please Note: It is suggested to only create a single case for a single issue in order to avoid confusion.
    Anand
