Add control via code to RDL Multi-Section Report
Posted by: mlocke on 20 April 2023, 12:16 pm EST
    Posted 20 April 2023, 12:16 pm EST - Updated 20 April 2023, 12:22 pm EST
    Hello!
    I’m attempting to build a custom table and add it to an existing RDL Multi-Section report. I’m having trouble figuring out how to add it. The sample code I’m using from github is:
    		PageReport pageReport = new PageReport();
                    System.IO.FileInfo fi = new System.IO.FileInfo("C:\\My Dev\\PDSAPI\\PDSAPI\\Reports\\MFS.rdlx");
                    pageReport.Load(fi);
                    pageReport.Run();
                //Creating a Table reportitem
                    Table table = new Table();
                    table.Name = "Table1";
                    //Creating the rows,columns as well as TableCells for the table as well as TextBoxes to be placed within the Table Cells
                    TextBox[] tableTextBoxes = new TextBox[6];
                    TableCell[] tableCells = new TableCell[6];
                    TableRow[] tableRows = new TableRow[2];
                    TableColumn[] tableColumns = new TableColumn[3];
                    String[] textBoxValues = new String[] { "Sample", "Test", "Data", "Column", "Headers", "Test" };
                    String[] columnsWidth = new String[] { "9cm", "4.6cm", "5.3cm" };
                    String[] rowsHeight = new String[] { "1.5cm", "1.5cm" };
                    //Setting properties for the Textboxes to be placed in the TableCells
                    for (int i = 0; i < tableTextBoxes.Length; i++)
                        tableTextBoxes.SetValue(new TextBox(), i);
                        tableTextBoxes[i].Name = "textBox" + (i + 1);
                        tableTextBoxes[i].Value = ExpressionInfo.FromString(textBoxValues[i]);
                        tableTextBoxes[i].Style.PaddingBottom = tableTextBoxes[i].Style.PaddingLeft = tableTextBoxes[i].Style.PaddingRight = tableTextBoxes[i].Style.PaddingTop = ExpressionInfo.FromString("2pt");
                        tableTextBoxes[i].Style.TextAlign = ExpressionInfo.FromString("Left");
                        tableCells.SetValue(new TableCell(), i);
                        tableCells[i].ReportItems.Add(tableTextBoxes[i]);//Adding the TextBoxes to the TableCells
                        if (i < rowsHeight.Length)
                            tableRows.SetValue(new TableRow(), i);
                            tableRows[i].Height = "1.25cm";
                            table.Height += "1.25cm";
                        if (i < columnsWidth.Length)
                            tableColumns.SetValue(new TableColumn(), i);
                            tableColumns[i].Width = columnsWidth[i];
                            table.Width += columnsWidth[i];
                            table.TableColumns.Add(tableColumns[i]);
                            tableCells[i].ReportItems[0].Style.BackgroundColor = ExpressionInfo.FromString("LightBlue");
                            tableRows[0].TableCells.Add(tableCells[i]);
                        else
                            tableCells[i].ReportItems[0].Style.BackgroundColor = ExpressionInfo.FromString("=Choose((RowNumber(\"Table1\") +1) mod 2, \"PaleGreen\",)");
                            tableRows[1].TableCells.Add(tableCells[i]);
                    table.Header.TableRows.Add(tableRows[0]);
                    table.Details.TableRows.Add(tableRows[1]);
                    table.Top = "1cm";
                    table.Left = "0.635cm";
                    pageReport.Report.Body.ReportItems.Add(table);
    The pageReport.Report.Body.ReportItems is empty, even though I have 22 controls in the designer already. I found the controls buried very deep in the pageReport.Report object. I found them by clicking into pageReport.Report.Components. This gives me a component for PageReportModel.ReportSection. Drilling down into that object’s components show 2 components - one of which is a PageReportModel.Body. Clicking into the components of this object shows the 22 controls I have added to the report. I know this is where the table needs to be added, but I can’t figure out how to add it.
    I’ve added screenshots to try to help explain.
    How do I add the table object into the components?
  • Posted 24 April 2023, 1:37 am EST
    Hi Melissa,
    The code you are using is for standard RDL/PageReport, for Multi-Section RDL Report you’ll need to add your table within ‘pageReport.Report.ReportSections[0].Body.ReportItems.Add(table);’ instead of ‘pageReport.Report.Body.ReportItems.Add(table);’.
    Also, you need to call the ‘pageReport.Run()’ method at the end of adding all your controls, the Run() method renders all the controls specified in your report into the pageReport.Document, hence calling it in the end will render your table into the PageReport.Document.
    Please find attached a sample implementing your requirements using the code provided.
    Anand
    AddingTableToRDL.zip
  • Posted 24 April 2023, 3:42 pm EST
    Thank you!
