Posted 16 August 2019, 8:10 am EST
I have incorporated custom TrueType fonts in the past into Active Reports viewer/export without issue in AR 12 (and likely AR 11 as well), but I’m encountering an issue with AR 13. I am programatically loading the viewer and then running MyViewer.Print(true, true, true) but I get garbled text in the printed version. Note that my export to PDF from the viewer works just fine and likely embeds the font without issue. When I opened the printed version (if I use Microsoft’s Print to PDF printer driver), when I copy and paste that report text from print fonts.pdf into MS Word, I am seeing that the CIDFont+F1 is being used/applied, rather than the Source Sans Pro font I specified.
Any tips/advice/help or is this a legit bug in the recent AR 13.1?
I’m using the Source Sans Pro font, which can be found here:
https://www.fontsquirrel.com/fonts/source-sans-pro
