AR 13 WPF Viewer problem - when report loaded, report always on top
Posted by: dlipsy on 24 August 2020, 4:41 pm EST
    Posted 24 August 2020, 4:41 pm EST
    I am encountering some odd behavior with the AR 13 WPF viewer when a report has been loaded. I’m trying to put a pop-over fly-out panel on top of the report, but once a report has been loaded in the viewer, I’m unable to see the pop-over panel. Please see attached MP4 video and Zip file with code (based on WPF Viewer sample).
    sample-updated.zip
  • Posted 24 August 2020, 4:42 pm EST
    Attached is a ZIP with a MP4 video showing what happens (erroneously) when loading a report in the viewer.
    wpf-viewer-after-load-always-on-top.zip
  • Posted 25 August 2020, 8:32 am EST
    I am able to reproduce the issue. I have escalated the issue to the development team and will inform you once I get any information from them.
  • Posted 25 August 2020, 9:07 am EST
    Can you use the following line of code as workaround:
    ReportViewer.ViewType = GrapeCity.Viewer.Common.Model.ViewType.SinglePage;
  • Posted 25 August 2020, 11:34 am EST
    [quote]Can you use the following line of code as workaround:
    [/quote]
    We need the report to be in continuous mode, however, so a user can scroll through the pages in the report.
  • Posted 26 August 2020, 9:18 am EST
    I have escalated this to our development team(AR-24999).
  • Posted 26 August 2020, 1:35 pm EST
    Thanks, Mohit. I will check back in a day or two and see if there are any bug fixes or other workarounds.
  • Posted 27 August 2020, 3:24 pm EST
    Hello Mohit,
    Do you have any update on the AR-24999 issue? Is there a more widespread issue with the viewer when in Continuous mode?
    Dan
  • Posted 31 August 2020, 8:16 am EST
    Mohit, do you have any update?
  • Posted 31 August 2020, 11:08 am EST
    Could you please explain that what is your actual requirement to have fly-out panel in WPF Viewer.
  • Posted 31 August 2020, 11:16 am EST
    Yes, the fly-out panel contains report configuration, which sets certain headers for the report that will display in the viewer.
  • Posted 31 August 2020, 11:18 am EST
    Thanks for the information. I have forwarded this information to the development team.
  • Posted 1 September 2020, 9:34 am EST
    Hello Dan,
    It is a limitation of WPF viewer in continuous mode. You can use panel outside the viewer to achieve your requirement.
  • Posted 1 September 2020, 9:23 pm EST
    Sorry, Mohit, this is not an acceptable answer / solution. Something is pretty broken in the continuous mode. Please use the same sample I have attached above and you will see an even bigger issue - when you change the Windows 10 scale, the viewer in continuous mode completely falls apart. You can reproduce by following the steps I show in the attached screen capture videos. wpf-viewer-after-scale-change-1.zipwpf-viewer-after-scale-change-2.zip
  • Posted 2 September 2020, 11:45 am EST
    Thank you - I will have to review Airspace workarounds. Thanks for escalating the other issue - appreciate your help.
  • Posted 2 September 2020, 12:01 pm EST
    Actually, WPF viewer uses WindowsFormsHost internally to show the continuous mode in WPF viewer. It is known bug of this control - it renders its content over WPF controls:
    https://stackoverflow.com/questions/5978917/render-wpf-control-on-top-of-windowsformshost
    Regarding scaling issue, I have escalated this to our development team(AR-25032) and will inform you once I get any information from them.
  • Posted 3 September 2020, 3:59 pm EST
    Please let the DEV team know that the workaround is a workaround for this particular issue.
    There is a NuGet package that implements the GitHub solution:
    https://github.com/chris84948/AirspaceFixer
  • Posted 4 September 2020, 12:16 am EST
    Thanks for sharing with us. I am glad your problem is solved now.
  • Posted 4 September 2020, 12:59 pm EST
    Hello Dan,
    Could you please try after setting the Continuous mode in LoadComplete event of the Viewer instead of XAML code:
    Viewer.LoadCompleted += (_, __) =>
    Viewer.ViewType = GrapeCity.Viewer.Common.Model.ViewType.Continuous;
  • Posted 4 September 2020, 1:02 pm EST
    Thanks, I’ll take a look at that workaround. Thanks for your help, Mohit.
  • Posted 4 September 2020, 1:19 pm EST
    Unfortunately, I hit this snag - how do I get past that?
    The type ‘ViewType’ exists in both ‘GrapeCity.ActiveReports.Viewer.Win, Version=13.2.18250.0, Culture=neutral, PublicKeyToken=cc4967777c49a3ff’ and ‘GrapeCity.ActiveReports.Viewer.Wpf, Version=13.2.18250.0, Culture=neutral, PublicKeyToken=cc4967777c49a3ff’
  • Posted 4 September 2020, 1:58 pm EST
    I used extern for the GrapeCity.ActiveReports.Viewer.Win library, as detailed here:
    https://stackoverflow.com/a/17651003
    That definitely works a bit better than setting in XAML.
  • Posted 7 September 2020, 6:36 am EST
    You can check after removing the " GrapeCity.ActiveReports.Viewer.Win" as well. It is not needed in WPF Viewer project.
  • Posted 7 September 2020, 7:45 am EST
    I tried that, but couldn’t find a way to print from the viewer, as the Print / PrintExtension API is only in that .Win library. [quote=“mohitg”]
    [/quote]
  • Posted 7 September 2020, 7:46 am EST
    Did you get any more info about the scaling issue (AR-25032)?
  • Posted 8 September 2020, 9:02 am EST
    Yes, These extension only available in WinViewer.
    No. I thought your issue is resolved after using the LoadCompleted event.
    Request to please confirm if your issue is not resolved yet.
  • Posted 14 September 2020, 11:19 am EST
    I just tried to reproduce the AR-25032 scaling issue. It is still not working properly. Can you follow up with dev team on this ticket, please?
  • Posted 15 September 2020, 4:26 am EST
    Hello Dan,
    I am not able to replicate the issue with previous provided sample at my end after using the LoadCompleted event. Could you please provide the sample so that I can share the same with the developer team and provide the information to them that the customer issue is not fully resolved even after using the LoadCompleted event.
  • Posted 15 September 2020, 8:44 am EST
    I have attached a Zip file containing updated source code and 125-percent-issue.mp4, which shows this being reproduced. Please ensure your display scale is set to 125%, as shown in display-setting.png.
    AR-sample.zip
    BTW, please increase your file size limit to 20 MB - the 5 MB is very restrictive and I have to put in extra effort to clean out files just to fit it into the 5 MB limit.
  • Posted 16 September 2020, 5:09 am EST
    Thanks for the video and sample. I am able to replicate the issue. However, issue get resolved at my end after using the following events:
    ReportViewer.LoadCompleted += (s, e) =>
    				ReportViewer.ViewType = GrapeCity.Viewer.Common.Model.ViewType.Continuous;
                ReportViewer.RefreshReport += (s, e) =>
    Could you please try it at your end.
    I will discuss with concerned team for the same.
  • Posted 16 September 2020, 9:09 am EST
    Thanks, that workaround worked great! Please convey my thanks to the DEV team for checking into those issues.
    WOOT!
  • Posted 16 September 2020, 9:35 am EST
    What is still odd, at least in my experience, is that when I run the sample, it is fine. When I run the fuller application code, it still behaves this way. I’ll continue to investigate.
    Something goes weird when I do a first load of the section report and do the code you mentioned. I don’t see it cause an issue after that.
  • Posted 16 September 2020, 11:40 am EST
    Essentially, if there was a way to load a blank / null document, that should resolve my issue within the app.
    Note: I found a way to load it 2x on first load, and it looks to work fine.
  • Posted 16 September 2020, 3:13 pm EST
    You may close this ticket. Thanks for your help, Mohit.
  • Posted 17 September 2020, 3:17 am EST
    I am glad your issue is resolved now. Please feel free to revert if you have any other question.
