AR 14 JSViewer - Sticky PREPARING PRINT... overlay on Chrome
Posted by: ricardo.pereira on 21 September 2020, 12:55 pm EST
    Posted 21 September 2020, 12:55 pm EST
    We are using AR14 JSViewer and we found out that there was a bug when printing a report using it’s native functionality.
    Printing on Firefox works well even though we get a random log on the console with the following message: “PDF e8b68c6f31620043965edaadef26b51f [1.4 ActiveReports 14 / ActiveReports 14] (PDF.js: 2.6.123)”.
    The problem is when we try to print on Chrome. The same blue overlay with the text “Preparing Print” appears then the print dialog, but after we perform an action on that dialog (either cancel or print), the blue overlay doesn’t fade and we end up with the following error on the console:
    Uncaught DOMException: Blocked a frame with origin "https://<domain>" from accessing a cross-origin frame.
        at HTMLIFrameElement.a.onload
    Do you have any suggestion? Thanks in advance.
    Ricardo Pereira
  • Posted 22 September 2020, 12:53 am EST
    I am not able to replicate the issue at my end using the sample at the following link:
    https://github.com/activereports/WebSamples14/tree/master/JsViewerSamples/JSViewer_MVC
    Chrome Version: 85.0.4183.121
    Could you please check with the above sample and check if the issue is reproducible at your end or not. If not, could you please share the stripped down sample so that I can able to replicate the issue at my end.
  • Posted 23 September 2020, 10:59 am EST
    Hi Mohit,
    Using that sample I had no issues.
    After some further investigation I noticed that the problem lies on the “jsViewer.min.js” file. I don’t know which version you used but here are the steps to replicate:
    Base configuration:
    Test 1 (working well):
    • Use “@grapecity/ar-viewer@14.0.1483” to run the report then click on the print button. This will work opening the report on an iframe in a new tab and also the print dialog.
    Test 2 (not working and throwing the initially reported error):
    • Use “@grapecity/ar-viewer@14.2.2530” to run the report then click on the print button. This will throw the error “Uncaught DOMException: Blocked a frame with origin “https://” from accessing a cross-origin frame.
      at HTMLIFrameElement.a.onload” even though the print dialog will also appear. But the “Preparing Print” won’t fade preventing every further action.
    Attached is a sample website with the broken jsViewer.min.js version already included. I can’t provide an api but I guess you’ll have one for this testing cases.
    The only thing you’ll have to do is modify the file “app\Views\Home\Index.cshtml” by replacing the “reportService” url and the “REPORT_NAME.rdlx” with your report.
    Hope this helps you sort this issue.
    Ricardo Pereiraapp.zip
  • Posted 24 September 2020, 1:44 pm EST
    I am able to reproduce the issue. I have escalated the issue to the development team (AR-25176) and will inform you once I get any updates from them.
  • Posted 25 September 2020, 4:31 am EST
    Hi Mohit,
    Thank you, I’ll keep checking this thread.
    Ricardo Pereira
  • Posted 25 September 2020, 10:41 am EST
    This is a bug in new JsViewer. Can you use the Old JSViewer (@grapecity/ar-viewer@14.0.1483) as workaround for time being.
  • Posted 24 October 2020, 12:06 pm EST - Updated 30 September 2022, 4:44 pm EST
    I am getting exactly the same problem with AR14 Pro vs 14.2.20530 in a DotNET Core (3.1.8) web application. On exiting the Print dialog (either after having printed a document or by clicking the [Cancel] button) the “Preparing print…” modal dialog remains on-screen with no way of clearing it other than a total page refresh.
    Do you have a temporary fix that I can use?
    Kind regards,
    Paul
  • Posted 25 October 2020, 11:12 pm EST
    Currently it is with developer team and will inform you once it is fixed.
    You can use the old version of JS (@grapecity/ar-viewer@14.0.1483) as workaround for time being.
  • Posted 10 December 2020, 4:15 am EST
    Could you please check with the latest version of AR14.2:
    http://cdn.grapecity.com/ActiveReports/AR14/Hotfixes/ActiveReports-v14.2.20717.msi
  • Posted 2 April 2021, 9:51 am EST
    Hi Mohit,
    I am getting this issue with Google Chrome and JSViewer 15.0.3
  • Posted 2 April 2021, 12:23 pm EST
    Can you please share the steps to reproduce the issue as I am not able to replicate the issue.
  • Posted 2 April 2021, 12:27 pm EST
    Also, Can you try with the latest build of AR. You can download the same from the following link:
    https://www.grapecity.com/activereportsnet/download
  • Posted 2 April 2021, 1:48 pm EST
    I am using ActiveReports 15.0.5.0. It looks like the same issue that Ricardo was getting earlier. I get the message “Uncaught DOMException: Blocked a frame with origin “https://” from accessing a cross-origin frame.
  • Posted 5 April 2021, 1:19 am EST
    I have tried with the same application as attached in the following forum post:
    https://www.grapecity.com/forums/ar-dev/ar-14-jsviewer---sticky-pr#hi-mohit-using-that-sample
    However, I am not able to replicate the issue. Could you please share the stripped down application so that I am able to replicate the issue at my end.
  • Posted 6 April 2021, 12:20 pm EST
    ReportApp.zip
    Here is my sample project.
  • Posted 8 April 2021, 6:19 am EST
    Thanks for the sample.
    I am able to reproduce the issue and have escalated the issue to the development team (AR-26364) and will inform you once I get any information from them.
  • Posted 9 April 2021, 4:13 am EST
    Please add dependency from System.Text.Encoding.CodePages NuGet package and add code in program.cs:
    Encoding.RegisterProvider(CodePagesEncodingProvider.Instance);
  • Posted 15 April 2021, 5:08 pm EST
    Hi Mohit,
    I added that package and code, however I am still getting the sticky “Preparing Print” overlay.
  • Posted 22 April 2021, 2:03 pm EST
    Can you please check after upgrading to the latest version of JsViewer and AR .i…e AR15.1
    https://www.npmjs.com/package/@grapecity/ar-viewer
    Also, update the AR assemblies to AR15.1.0.
