AR 14 RDLX Reports display nested property
Posted by: lesauthjenthu on 15 September 2021, 4:58 am EST
  • Posted 15 September 2021, 4:58 am EST
    Hi, I’m using rdlx with json provider data
    I have a class
    Class A
    string ID,
    List lstB
    Class B
    string C,
    string D
    I want display all C property inside lstB, how to do this?
  • Posted 20 September 2021, 4:28 am EST
    You can refer to the approach mentioned in the following link:
    https://www.grapecity.com/forums/ar-dev/display-hierarchical-json
  • Posted 29 September 2021, 5:29 am EST
    Hi mohitg
    I’m using PageDocument for load and set Parameters to main report
    Then use PdfRenderingExtension to render
    Now how to include sub report to my main report?
  • Posted 1 October 2021, 8:23 am EST
    Please refer the following documentation page that explains how to include subreport in a main report:
    https://www.grapecity.com/activereportsnet/docs/v14/online/subreport-in-rdl-report.html
  • Posted 4 October 2021, 6:45 am EST
    I know how to include subreport in a main report
    My problem is how to add data to subreport
    My main report is load report to PageDocument
    then using ```
    pageDocument.Parameters[“ReportParameter1”].Values[0].Value = jsonStr;
    I try the same with subreport but it not work
  • Posted 5 October 2021, 2:24 pm EST
    Can you share the full code of how you’re loading data in the main report and subreport? If possible, please attach a sample application.
