Posted 19 April 2023, 1:09 pm EST - Updated 19 April 2023, 3:54 pm EST
Hi!
I have a multi-section report in AR 17 that I’m trying to export via code. This is what I have:
SectionReport sectionReport = new SectionReport();
XmlReader xtr = XmlReader.Create("C:\\My Dev\\PDSAPI\\PDSAPI\\Reports\\MFS.rdlx");
sectionReport.LoadLayout(xtr);
sectionReport.Parameters[0].Value = mfsRecordKey.ToString();
sectionReport.Run();
GrapeCity.ActiveReports.Export.Pdf.Section.PdfExport pdfExport = new GrapeCity.ActiveReports.Export.Pdf.Section.PdfExport();
// Add meta data
var metadata1 = new AdditionalMetadataInfo
Namespace = AdditionalMetadataNamespace.PurlOrg, //Dublin Core Properties
Key = "title",
Value = "MFSReport"
pdfExport.Options.AdditionalMetadata.Add(metadata1);
pdfExport.Export(sectionReport.Document, "C:\\Users\\someName\\Downloads");
On the line to call sectionReport.LoadLayout(xtr) - it gives this error: “Unknown DataSource name:DataSource”. When I inspect the xtr object, it just says “none” but the base uri is fine. The report has a datasource added pointing to our sql server and the report uses 2 stored procedures to pull fields from. When previewing the report in the designer, data is pulled back as expected.
How can I get this to work? Basically, I’ll be calling this service application code from multiple projects - winforms app, website, angularjs site - and I want to be able to pass the 1 parameter it needs and export to PDF without showing the report in any type of viewer.
Thanks!
Answer for those that need it:
The report “ActiveReport RDL Multi-Section Report” is not a section report. It’s a page report and needs different rendering code.
PageReport pageReport = new PageReport();
System.IO.FileInfo fi = new System.IO.FileInfo("C:\\My Dev\\PDSAPI\\PDSAPI\\Reports\\MFS.rdlx");
pageReport.Load(fi);
pageReport.Report.ReportParameters[0].DefaultValue.Values.Add(mfsRecordKey.ToString());
pageReport.Run();
// Provide settings for your rendering output.
GrapeCity.ActiveReports.Export.Pdf.Page.Settings pdfSetting = new GrapeCity.ActiveReports.Export.Pdf.Page.Settings();
// Set the rendering extension and render the report.
GrapeCity.ActiveReports.Export.Pdf.Page.PdfRenderingExtension pdfRenderingExtension = new
GrapeCity.ActiveReports.Export.Pdf.Page.PdfRenderingExtension();
System.IO.DirectoryInfo outputDirectory = new System.IO.DirectoryInfo(@"C:\MyPDF");
outputDirectory.Create();
GrapeCity.ActiveReports.Rendering.IO.FileStreamProvider outputProvider = new GrapeCity.ActiveReports.Rendering.IO.FileStreamProvider(outputDirectory,
System.IO.Path.GetFileNameWithoutExtension(outputDirectory.Name));
// Overwrite output file if it already exists
outputProvider.OverwriteOutputFile = true;
pageReport.Document.Render(pdfRenderingExtension, outputProvider, pdfSetting);
