AR11 CAS policy
Posted by: darin on 22 March 2019, 10:20 am EST
    Posted 22 March 2019, 10:20 am EST
    We are still working and testing AR11. Everything works fine. Except:
    RDP into a server, and on the server run our software using shared folders on that server causes the preview to errore wieht the CAS polity message.
    But, running it from the share not RDP in works fine. And running it from the actual drive letter while logged into the server works fine.
    So:
    RDP:
    c:\program\runprog.exe works fine
    \server\program\runprog.exe CAS policy error
    not RDP:
    \server\program\runprog.exe works fine
    I am RDP as a domain admin when i am testing this.
    I do not have any entries added to the app.config because the forum posts that was the solution was from AR7 & 9. i am using a windows application built on .NET 4.5.
  • Posted 25 March 2019, 2:54 am EST
    Could you please try after adding the following line in “app.config” file
    <configuration>
      <runtime>
        <NetFx40_LegacySecurityPolicy enabled="true"/>
      </runtime>
    </configuration>
    Also, please refer to the “The SystemNotSupportedException occurs when running ActiveReports with scripts on .NET Framework 4.0” topic in the following documentation link:
    http://help.grapecity.com/activereports/webhelp/AR11/webframe.html#arRELTroubleshooting.html
    Hope it helps.
