Posted 4 November 2017, 12:02 pm EST
In AR11 my report has a cascading multivalue field. By default this field is empty and the report should allow that and not require a selection. In ar9 this worked, but in ar11 this does not work. This is failing in the html viewer .
Can I allow nullable multivalue parameter?
Can I hide the (select all) field?
Can i rename the (select all) to be (none)?
