AR11 to AR14 Upgrade issues
Posted by: renu.ap on 25 June 2020, 11:27 am EST
    Posted 25 June 2020, 11:27 am EST
    I have upgraded AR11 to AR14 with “Convert to AR 14” plugin in Visual Studio.
    It Web application. Report is throwing error like attached.
    I used RPX file based sectionreport with parameters assigned at run time.
    Please advise.
                        r.Parameters("InterestRateSystemID").Value = CType(Me._interestRateSystemID, Integer)
                        r.Parameters("FromEffectiveDate").Value = CType(Me._fromEffectiveDate, DateTime)
                        r.Parameters("ToEffectiveDate").Value = CType(Me._toEffectiveDate, DateTime)
                        r.Parameters("InterestRateSystemText").Value = Me._interestRateSystemText
                        If CType(Me._interestRateSystemID, Integer) = 1 Then
                            r.Parameters("SubHeadingA").Value = "Non Indexed"
                            r.Parameters("SubHeadingB").Value = "Indexed"
                        Else
                            r.Parameters("SubHeadingA").Value = "0 Yr Deferral"
                            r.Parameters("SubHeadingB").Value = "10 Yrs Deferral"
                        End If
    Capture.zip
  • Posted 26 June 2020, 9:52 am EST
    If i hardcode parameters it is working.
    ds.SQL = “[usp_rptGetByEffectiveDate] ‘2’, ‘06/15/2015’, ‘06/15/2020’”
    But if i pass paramerters like below then it not working
    ds.SQL = “[usp_rptGetByEffectiveDate] ‘<%InterestRateSystemID%>’, ‘<%FromEffectiveDate%>’, ‘<%ToEffectiveDate%>’”
  • Posted 26 June 2020, 11:10 am EST
    Could you please check with the latest installer:
    http://cdn.grapecity.com/ActiveReports/AR14/Hotfixes/ActiveReports-v14.1.20250.msi
    If the issue still replicates, please provide the stripped-down sample so that I can replicate the issue at my end.
  • Posted 29 June 2020, 1:14 pm EST
    Even after applying patch it was not working. later i changed DefaultValue of a parameter instead of Value. Then it started working. It is very strange why it is like that in AR14. Please explain.
    Changed
    r.Parameters(“InterestRateSystemID”).Value
    To
    r.Parameters(“InterestRateSystemID”).DefaultValue
  • Posted 30 June 2020, 10:21 am EST
    I am glad that your issue is resolved now. This is change occur due to change in the Viewer API in AR14. Backend of WebViewer is completely changed now.
    Hope it clarifies.
  • Posted 2 July 2020, 12:36 pm EST
    Yes. Is there any article link that tells the changes in AR14 compared with older version ?
  • Posted 3 July 2020, 6:08 am EST
    Please refer to the following link:
    https://www.grapecity.com/activereports/docs/v14/online/breaking-changes.html
