AR13 Web Designer - Server Side filtering based on user populated parameters
Posted by: nicolaas.coetzee on 16 September 2019, 5:50 am EST
    Posted 16 September 2019, 5:50 am EST
    I am trying to find a way to at run time capture parameters from the user and then apply the captured values on the data source before any data retrieval is done.
    A simple use case would be filtering a large data set (i.e. a table of a 1000000 records) based on capture dates on the records.
    Pulling all the data to the report and then applying filters like specified in the Web Designer documentation creates a massive performance hit (https://help.grapecity.com/activereports/webhelp/AR13WebDesigner/webframe.html#Tutorial3CreateParameterizedReport.html)
    Is there any way of doing this? Is there some part of the documentation that I have missed?
  • Posted 16 September 2019, 6:52 am EST
    I have created two JSON for datasets in the Web Designer. You can copy both JSON files into the following location:
    C:\Users\MohitG\Documents\GrapeCity Samples\ActiveReports 13\Web\WebDesigner_MVC(Core)\datasets
    And run the WebDesigner_MVC(Core) sample.
    After that, please refer to the attached video to know how to use the parameter in Web designer.
    Please let me know if you have any other issue with this.
    Order Details.zip
