AR13 WebDesigner_MVC(Core) Custom Report Exports
Posted by: nicolaas.coetzee on 12 September 2019, 8:49 am EST
    Posted 12 September 2019, 8:49 am EST
    In AR11 reporting service it was possible to do a custom report export like this
    MemoryStream m_stream = new MemoryStream();
                try {
                    //assuming this is a proper report. Could also be a PageReport
                    SectionReport rpt = new SectionReport();
                    rpt.Run();
                    PdfExport pdfExport = new PdfExport();
                    pdfExport.Options.OnlyForPrint = true;
                    pdfExport.Export(rpt.Document, m_stream);
                    return Convert.ToBase64String(m_stream.ToArray());
                } catch (Exception ex) {
                    throw new MicroServicesException(log, reportPreviewOptions.CoreURL, reportPreviewOptions.Token, $"Unable to Get PDF Data -> [ExMessage: {ex.Message}]", ex, new object[] { reportPreviewOptions.CoreURL, reportPreviewOptions.ReportID, reportPreviewOptions.Token });
                } finally {
                    log.Info($"END: ExportPDF");
    However the Web Designer service uses a different type of report object -“GrapeCity.ActiveReports.PageReportModel.Report”. This object is not compatible with the above mentioned export method.
    What would be the correct way of doing this export in the AR13 Web Designer service?
  • Posted 13 September 2019, 1:39 am EST
    There is a ReportConverter class in GrapeCity.ActiveReports.Aspnet.Designer.Utilities to handle Report objects.
    You can use the following code;
    MemoryStream ms = new MemoryStream(ReportConverter.ToXml(report)); //report is GrapeCity.ActiveReports.PageReportModel.Report object
    ms.Position = 0;
    TextReader tr = new StreamReader(ms);
    PageReport rpt = new PageReport(tr);
    GrapeCity.ActiveReports.Export.Pdf.Page.Settings pdfSetting = new GrapeCity.ActiveReports.Export.Pdf.Page.Settings();
    GrapeCity.ActiveReports.Export.Pdf.Page.PdfRenderingExtension pdfRenderingExtension = new GrapeCity.ActiveReports.Export.Pdf.Page.PdfRenderingExtension();
    GrapeCity.ActiveReports.Rendering.IO.MemoryStreamProvider outputProvider = new GrapeCity.ActiveReports.Rendering.IO.MemoryStreamProvider();
    rpt .Document.Render(pdfRenderingExtension, outputProvider, pdfSetting);
    MemoryStream exportStream = new MemoryStream();
    outputProvider.GetPrimaryStream().OpenStream().CopyTo(exportStream );
    return Convert.ToBase64String(exportStream .ToArray());
    Note, you must have the following the reference in your project:
    GrapeCity.ActiveReports.Core.Rdl
    GrapeCity.ActiveReports.Document
    GrapeCity.ActiveReports.Core.Rendering
    Hope it helps.
  • Posted 16 September 2019, 3:27 am EST
    Hi Mohitg
    Thanks for the answer. This has solved my problem.
