AR14 - FileNotFoundException when rendering PageReport in .NET Core 3.0 web app
Posted by: rafael.mandler on 10 February 2020, 2:15 pm EST
    Posted 10 February 2020, 2:15 pm EST
    I am attempting to render a PageReport in a .NET Core 3.0 web app for AR14. I downloaded the GrapeCity.ActiveReports.Export.Pdf NuGet package (version 14.0.19313), which claims to work for .NETCoreApp version 3.0 as well as .NETFramework version 4.6.2.
    As a simple test, I try to invoke the example at this link https://www.grapecity.com/activereports/docs/v14/online/rendering-to-pdf.html in a MVC controller action method, with paths and file names changed for my test purposes.
    When doing so, I see the following exception:
    FileNotFoundException: Could not load file or assembly ‘System.Configuration.ConfigurationManager, Version=4.0.3.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51’. The system cannot find the file specified.
    In another web project I get a similar exception, except it is looking for a System.Windows.Forms assembly of that same version (4.0.3.0). Is this code only supported in Windows Forms? Or do I need a different NuGet package for .NET Core support?
  • Posted 11 February 2020, 3:25 am EST
    Can you try after adding the ConfigurationManager in your project?
    Install-Package System.Configuration.ConfigurationManager
    or you can use Microsoft.Windows.Compatibility pack to avoid the exception.
  • Posted 11 February 2020, 4:03 pm EST
    Thank you! The System.Configuration.ConfigurationManager seems to have worked. As for the Windows Forms, I think that might have been because I was using an obsolete PdfExport.Export method.
