AR14 - Is there something like Tab Indexes for controls?
Posted by: jennifer.gasiorowski on 15 March 2022, 9:20 am EST
  • Posted 15 March 2022, 9:20 am EST
    I have a series of reports that are created for a 3rd party application that we use. This application has the option to convert reports to excel format. In some of the reports, field and columns can be moved around and renamed quite frequently, so this creates a problem when the report is exported to Excel, and I don’t see a way to force the field order.
    For example, in one report, there are 11 fields in the Detail section. When it is exported to Excel, instead of showing the fields in order, it’s more like: 1, 4, 8, 3, 5, 6, 7, 9, 10, 11, 2. While it’s fine for the report, it displays out of order in excel. I’m not sure how the 3rd party application is converting it (I’m assuming just running through a list of controls), but I don’t see a way to re-order the controls other than swapping each field control and re-configuring each field one at a time.
  • Posted 16 March 2022, 5:41 am EST
    Hi Jennifer,
    Instead of using the third party application please use the Grapecity.AcitveReports.Export.Excel nuget package to export the report to Excel.
    Please refer to the following pages of our documentation to learn more about the excel export filter:
    https://www.grapecity.com/activereportsnet/docs/versions/v14/online/excel.html
    I have attached a sample application for your reference along with.
    Let us know you are still facing this issue.
    Akshay
    Excel Export Section Report.zip
  • Posted 17 March 2022, 3:11 pm EST
    Thanks, but we don’t have direct control over how the user exports a report, though (i.e., no API interfaces for certain “Print Report” pages that have the option to export.
  • Posted 21 March 2022, 2:24 am EST
    Hi Jennifer,
    We do not provide support for any third-party tools which is why I have suggested you to switch to our export filter. In Grapecity.ActiveReports.Export.Excel package files are exported in the same manner as they appear in viewer.
