AR15 Changing SectionReport Line Location
Posted by: frederik.reidinger on 22 October 2021, 7:49 am EST
    Posted 22 October 2021, 7:49 am EST
    i want to change the location of a line (GrapeCity.ActiveReports.SectionReportModel.Line) within a section via vb code.
    I have tried changing the X1/X2-coordinates but doing so has no effect on my line. Same goes for setting its bounds, the location attribute with a new pointF or the left property.
    I have also tried to output the current location of the line or setting it invisible. Both of these actions worked without issues.
    Dim oLine As GrapeCity.ActiveReports.SectionReportModel.Line = myLine
    oLine.X1 = 3F
    would be something i tried as an example close to what is documented.
  • Posted 25 October 2021, 1:28 pm EST
    It works at my end. Could you please tell me version that you are using at your end?
  • Posted 26 October 2021, 4:04 am EST
    it should be Version 15.1.7.
  • Posted 28 October 2021, 3:09 am EST
    Please refer to the attached sample. Please see if I am missing something?
  • Posted 29 October 2021, 7:49 am EST
    sadly i can’t see any attachments.
    If moving the line in the code works in said version i’ll look into our implementation of the SectionReport again to see if this is an issue on my end.
  • Posted 1 November 2021, 2:42 am EST
    Sorry, it seems that attachment is not attached properly. Please refer to the attachment
    SectionReportApplication5.zip
  • Posted 5 November 2021, 4:42 am EST
    thank you, Mohit! After seeing that the example worked and the code, in essence, was the same, i tried moving my code to a different place.
    As it turns out, the format event of the groupheader section couldn’t change the lines location correctly. When i move my code to the reportstart-event everything works as expected. Shouldn’t changing the line be possible in the sections format event though? “Use this section to set or change the properties of any controls or the section itself.” https://help.grapecity.com/activereports/webhelp/Legacy/ActiveReports6/topic138.html?
    Anyways, thanks for your help and you can see this topic as closed.
