Posted 20 July 2023, 8:58 am EST
GrapeCity.ActiveReports.ReportException: An unexpected error occurred. Additional information: ‘Method ‘ua’ in type ‘ayh’ from assembly ‘GrapeCity.Documents.Pdf, Version=5.1.0.790, Culture=neutral, PublicKeyToken=d55d733d2bfd5065’ does not have an implementation.’ —> System.TypeLoadException: Method ‘ua’ in type ‘ayh’ from assembly ‘GrapeCity.Documents.Pdf, Version=5.1.0.790, Culture=neutral, PublicKeyToken=d55d733d2bfd5065’ does not have an implementation.
在 GrapeCity.Documents.Pdf.GcPdfDocument…ctor(String licenseKey)
在 GrapeCity.ActiveReports.Core.Export.Pdf.Page.I…GrapeCity.ActiveReports.Rendering.Export.IGenerator.Init(IReport )
在 GrapeCity.ActiveReports.Rendering.Export.DocumentRenderer.Render(TargetDeviceKind target, Boolean includePageMargins, PageControllerSettings pageSettings, IProgress
1 progress, WatermarkSettings watermark, EvalPosition evalPosition, LayoutTreeKeeper keeper) 在 GrapeCity.ActiveReports.Export.Pdf.Page.PdfExport.Export(IReport report, Stream outStream, IProgress
1 progress, PdfSettings settings, CancellationToken cancel)
在 GrapeCity.ActiveReports.Export.Pdf.Page.PdfRenderingExtension.Render(IReport report, StreamProvider streams, NameValueCollection settings, CancellationToken cancel, IProgress
1 progress) 在 GrapeCity.ActiveReports.Document.PageDocument.Render(IRenderingExtension renderingExtension, StreamProvider streams, NameValueCollection settings, Boolean forceDataRefresh, Boolean forceParameterDataRefresh, CancellationToken token, IProgress
1 progress)
