AR9 - RichTextBox incorrectly convert RTF text
Posted by: mslezak on 14 May 2018, 7:00 am EST
    Posted 14 May 2018, 7:00 am EST
    I create table in RTF editor with three columns. When I set RTF as a value of RichTextBox control, and generate report I get table with the same width as RichTextBox width. First two columns are narrowed more than originally, and last are expanded. I attached simple project of Visual studio with this problem and screenshots of original table and table in RichTextBox.
  • Posted 14 May 2018, 7:03 am EST
  • Posted 15 May 2018, 1:24 am EST
    Hello Mateusz,
    I am able to reproduce the issue with your sample. However, issue is not replicate with attached “RTF” file. Could you please check with the attached RTF file or share the your “RTF” file to replicate the issue at my end.
    Test Data.zip
  • Posted 15 May 2018, 9:36 am EST
    With your RTF file everything works correct. Could you explain how you create this one?
    I send my RTF file. Maybe you can explain why this not working.
    document.zip
  • Posted 16 May 2018, 3:11 am EST
    This issue occurs may be Table Size is more than the width of the page. I have shrunk the table size and found that no issue occurs. Please refer the modified RTF file.
    Hope it helps.
    Document2.zip
