ASP.Net Core Razor page
Posted by: hafiz.hassan on 22 April 2021, 10:19 pm EST
    Posted 22 April 2021, 10:19 pm EST
    1. Do you have tutorial how to set up Active Reports 15 with existing project
      using ASP.Net Core 5 Razor pages?
      I only found this old article but AR15 already supported netcore so I think the old asp.net web service is not required anymore.
      https://www.grapecity.com/blogs/how-to-use-activereports-in-aspnet-core-20
    2. It is possible to print report on server side in ASP.Net Core?
      (printer is install on web server itself)
      Currently I’m doing this with FlexReport on ASP.NET using code below:
    C1FlexReport rep = new C1FlexReport();
    rep.Load(reportFileName, reportName);
    rep.Render();
    rep.Print(c1PrintOptions);
    It is possbile with AR15 & ASPNet Core?
  • Posted 22 April 2021, 11:52 pm EST
    Yes, it is possible. You can check the attached sample to implement the same,
    JSviewer_Mod.zip
    2
    Yes. It is possible to print server side. Please refer to the following link:
    https://www.grapecity.com/activereportsnet/docs/v15/online/print-methods-in-activereports-developer.html
  • Posted 23 April 2021, 12:57 am EST
    I’ve successfully created viewer in Razor page but for the server-side printing it failed. I received error “Could not load file or assembly System.Resources.Extensions, Version=4.0.0.0…”.
    However, I managed to solve it by installing ‘System.Resources.Extensions 5.0.0’ nuget package.
