Auto populate database in active reports designer
Posted by: venkatesan_rajendran on 22 December 2023, 2:09 am EST
    Posted 22 December 2023, 2:09 am EST
    We have a requirement to auto set data source while launching active reports designer. I couldn’t find a documentation for that in Active Reports WebDesigner docs. But I could see one in Active Reports JS docs https://developer.mescius.com/activereportsjs/demos/features/designer-resources/angular. I tried to implement the same for active reports web designer like below but it doesn’t work.
    GrapeCity.ActiveReports.Designer.create('#ar-web-designer', {
                appBar: { openButton: { visible: true } },
                editor: { showGrid: false },
                data: { dataSets: { canModify: true }, dataSources: { canModify: true, dataSource: {
                    connectionProperties: {
                        dataProvider: 'SQL',
                        connectString: 'data source=localhost;initial catalog=TestDB;user id=admin;password=admin;',
    Could someone help me achieve this?
  • Posted 22 December 2023, 3:17 am EST
    Hi Venkatesan,
    You can use Custom Store to set DataSource and Dataset information dynamically for the WebDesigner. You may refer to our WebDesigner Custom Store sample implementing it. Please refer to the following links to learn more about the same:
    Hope this helps!
