Barcode SupplementOptions.DataField throws an exception
Posted by: bval on 4 September 2020, 9:27 am EST
  • Posted 4 September 2020, 9:27 am EST
    Hello
    There is a problem with Barcode SupplementOptions.DataField in SectionReports.
    If Barcode.DataFiled is empty (The value is const and set up via Barcode.Text), but Barcode SupplementOptions.DataField is not empty, the report throws an exception during generation. I’ve attached an example.
  • Posted 4 September 2020, 9:30 am EST
  • Posted 7 September 2020, 6:32 am EST
    You can set the DataField and Text property blank of SupplementOptions to get the desire result.
  • Posted 7 September 2020, 7:57 am EST
    how to set up the supplement in this case?
  • Posted 8 September 2020, 8:54 am EST
    Could you please share the requirement so that I can assist you accordingly.
  • Posted 8 September 2020, 11:16 am EST
    Report was designed according to requirements. Please, check exception.test.zip
  • Posted 9 September 2020, 7:36 am EST
    Please create a Calculated field with static value and set it in “DataField” property of barcode. Please refer to the attached report to implement the same.
    test.zip
