Bind Data Set and Unbound Data to xml base Section Report at Run Time
Posted by: tai.zhang on 28 September 2023, 2:29 am EST
    Posted 28 September 2023, 2:29 am EST
    hi
    i found this doc
    https://www.grapecity.com/activereportsnet/docs/latest/online/bind-dataset-unbound-data-to-section-report-at-run-time.html
    which tells me how to Bind Data Set and Unbound Data to Section Report at Run Time.
    but looks like it’s for code-based Section Report.
    do you have any example/doc how to do it for an XML base section report?
    i’m using .net 6. and ActiveReports 17 Professional
    Thank you!
  • Posted 29 September 2023, 5:15 am EST
    Hi Tai,
    Looks like this is a duplicate case to your support ticket: CAS-43886-K7J3D4. We suggest to continue on the same ticket to avoid any confusion.
    Anand
  • Posted 2 October 2023, 6:34 pm EST
    thanks Anand, can u pls follow up the ticket then?
  • Posted 3 October 2023, 1:29 am EST
    Hi Tai,
    Apologies for the delay we had a public holiday on the 2nd due to which it is taking longer to get back to you.
    Rest assured we are working on your case and will get back to you as soon as possible.
    Anand
