Blank Gray screen
Posted by: cliffe on 14 June 2021, 9:18 am EST
  • Posted 14 June 2021, 9:18 am EST
    I have a solution with a .NET Core project with a code-based Section report. I’ve followed the instructions around adding a .NET Framework project (4.6.2) & linking the files. However, when I open the report designer, I get a blank gray window.
    I have the latest version of AR installed on my machine, and am using the latest NuGet packages, including GrapeCity.ActiveReports.Serializer. I’ve reset Visual Studio, and deleted the bin/obj folders.
    Are there any other suggestions?
    Cliffe
  • Posted 15 June 2021, 3:26 am EST
    Can you please check with the attached sample. I have followed the instruction from the following link:
    https://www.grapecity.com/activereportsnet/docs/v15/online/designing-code-based-section-reports-in-net-core.html
    WinFormsApp4.zip
  • Posted 26 June 2021, 10:22 am EST
    Thanks for your help, that sample project seemed to work.
    I was trying to nest the reports under a Reports sub-folder & the .resx files were also not being included, I’m not sure exactly which was the issue, but it’s fixed now.
    Thanks again for your help!
