Posted 8 January 2020, 12:30 pm EST
I have both Active Reports v11 and v10 loaded on my machine, v10 was recently installed after v11. I’m not sure if the installation of v10 is causing my issue, but I can no longer load reports in the designer and when I add a existing report to another project using vs 2017 the report is not reference properly and I get a ton of error. I get the following error when trying to load the report in VS 2013 in the project it was originally written/designed in:
Instances of this error (1)
- Hide Call Stack
at System.ComponentModel.TypeDescriptor.AddAttributes(Object instance, Attribute attributes)
at Microsoft.VisualStudio.Design.VSDesignSurface.CreateDesigner(IComponent component, Boolean rootDesigner)
at System.ComponentModel.Design.DesignerHost.AddToContainerPostProcess(IComponent component, String name, IContainer containerToAddTo)
at System.ComponentModel.Design.DesignerHost.PerformAdd(IComponent component, String name)
at System.ComponentModel.Design.DesignerHost.System.ComponentModel.Design.IDesignerHost.CreateComponent(Type componentType, String name)
at System.ComponentModel.Design.Serialization.DesignerSerializationManager.CreateInstance(Type type, ICollection arguments, String name, Boolean addToContainer)
at System.ComponentModel.Design.Serialization.DesignerSerializationManager.System.ComponentModel.Design.Serialization.IDesignerSerializationManager.CreateInstance(Type type, ICollection arguments, String name, Boolean addToContainer)
at System.ComponentModel.Design.Serialization.TypeCodeDomSerializer.Deserialize(IDesignerSerializationManager manager, CodeTypeDeclaration declaration)
at System.ComponentModel.Design.Serialization.CodeDomDesignerLoader.PerformLoad(IDesignerSerializationManager manager)
at Microsoft.VisualStudio.Design.Serialization.CodeDom.VSCodeDomDesignerLoader.PerformLoad(IDesignerSerializationManager serializationManager)
at Microsoft.VisualStudio.Design.Serialization.CodeDom.VSCodeDomDesignerLoader.DeferredLoadHandler.Microsoft.VisualStudio.TextManager.Interop.IVsTextBufferDataEvents.OnLoadCompleted(Int32 fReload)
I have no idea what’s going on and I can’t find any answers/fixes anywhere. What am I missing?
