Can't add a new report
Posted by: aschwab on 16 January 2020, 11:08 am EST
    Posted 16 January 2020, 11:08 am EST - Updated 30 September 2022, 5:21 pm EST
    Hello.
    I work with Visual Studio 2017. I use GrapeCity.ActiveReports, Version=13.1.16872.0. I can copy and modify the existing reports but if I want to add a new item the Active Reports are not available. Attached are “Add New Item” window and my web.config file.
    Thank you very much for your help.
  • Posted 17 January 2020, 1:36 am EST
    Could you please check with the latest version of AR13. You can download the same from the following link:
    http://cdn.grapecity.com/ActiveReports/AR13/hotfixes/ActiveReports-v13.2.18717.0.msi
    Please uninstall the previous version first and then install the latest version.
    Note:
    Your application target framework should be equal to or greater than 4.6.2(As I seen in the Web.config, Your application FW is already set to 4.6.2)
    VS2017 version should be equal to or greater than 15.2
    If the problem still exists, then please share the following things:
    OS Version
    VS Version
    Type of application(WebApplication/Website/Core application)
    Problem exists with the old projects only or with newly created samples also.
