Can't Add Data to the Report on ReportService Server
Posted by: dtujo on 5 June 2023, 3:43 pm EST
    Posted 5 June 2023, 3:43 pm EST - Updated 5 June 2023, 3:51 pm EST
    Created VS Studio Template for Web Assembly Report Viewer.
    I am passing an object through a POST request to the Report Service and Serializing it as JSON and trying to add it through the LocateDataSource. I have not been able to set data for the form. In the form I have the data schema set to the JSON schema of the data I am passing it.
    Here is the controller on the server:
        [Route("/")]
        public class HomeController : Controller
            [HttpPost("report")]
            public ActionResult Report([FromBody] ReportModel myData)
                var reportData = JsonSerializer.Serialize(myData);
                Console.WriteLine(reportData);
                PageReport page_report = new PageReport();
                page_report.Document.LocateDataSource += (sender, args) =>
                    args.Data = myData;
                GrapeCity.ActiveReports.Document.PageDocument reportDocument = new GrapeCity.ActiveReports.Document.PageDocument(page_report);
                return new JsonResult(reportDocument);
    Here is the code on WASM:
    using var report = await http.PostAsJsonAsync("************************/report", dataModel);
    _currentReport = await report.Content.ReadFromJsonAsync<string>();
    Console.WriteLine(_currentReport);
    await _viewer.OpenReport(_currentReport);
    It breaks in the controller on LocateDataSource:
    Unhandled Exception:
    System.Text.Json.JsonException: 'S' is an invalid start of a value. Path: $ | LineNumber: 0 | BytePositionInLine: 0.
     ---> System.Text.Json.JsonReaderException: 'S' is an invalid start of a value. LineNumber: 0 | BytePositionInLine: 0.
       at System.Text.Json.ThrowHelper.ThrowJsonReaderException(Utf8JsonReader& json, ExceptionResource resource, Byte nextByte, ReadOnlySpan`1 bytes)
       at System.Text.Json.Utf8JsonReader.ConsumeValue(Byte marker)
       at System.Text.Json.Utf8JsonReader.ReadFirstToken(Byte first)
       at System.Text.Json.Utf8JsonReader.ReadSingleSegment()
       at System.Text.Json.Utf8JsonReader.Read()
       at System.Text.Json.Serialization.JsonConverter.DoSingleValueReadWithReadAhead(Utf8JsonReader& reader, ReadStack& state)
       at System.Text.Json.Serialization.JsonConverter`1[[System.String, System.Private.CoreLib, Version=6.0.0.0, Culture=neutral, PublicKeyToken=7cec85d7bea7798e]].ReadCore(Utf8JsonReader& reader, JsonSerializerOptions options, ReadStack& state)
       --- End of inner exception stack trace ---
       at System.Text.Json.ThrowHelper.ReThrowWithPath(ReadStack& state, JsonReaderException ex)
       at System.Text.Json.JsonSerializer.ReadCore[String](JsonConverter jsonConverter, Utf8JsonReader& reader, JsonSerializerOptions options, ReadStack& state)
       at System.Text.Json.JsonSerializer.ReadCore[String](JsonReaderState& readerState, Boolean isFinalBlock, ReadOnlySpan`1 buffer, JsonSerializerOptions options, ReadStack& state, JsonConverter converterBase)
       at System.Text.Json.JsonSerializer.ContinueDeserialize[String](ReadBufferState& bufferState, JsonReaderState& jsonReaderState, ReadStack& readStack, JsonConverter converter, JsonSerializerOptions options)
       at System.Text.Json.JsonSerializer.<ReadAllAsync>d__65`1[[System.String, System.Private.CoreLib, Version=6.0.0.0, Culture=neutral, PublicKeyToken=7cec85d7bea7798e]].MoveNext()
       at System.Net.Http.Json.HttpContentJsonExtensions.<ReadFromJsonAsyncCore>d__4`1[[System.String, System.Private.CoreLib, Version=6.0.0.0, Culture=neutral, PublicKeyToken=7cec85d7bea7798e]].MoveNext()
       at BlazorViewerWebAssembly.Pages.Index.ViewerInitialized() in C:\Users\dtujo\source\repos\ReportTesting\ReportTesting\BlazorViewerWebAssembly\Pages\Index.razor:line 77
       at System.Threading.Tasks.Task.<>c.<ThrowAsync>b__128_1(Object state)
       at System.Threading.QueueUserWorkItemCallbackDefaultContext.Execute()
       at System.Threading.ThreadPoolWorkQueue.Dispatch()
       at System.Threading.ThreadPool.Callback()
    Picture attached of the reports JSON settings.
  • Posted 7 June 2023, 4:52 am EST
    Hi Daniel,
    We could observe you have created a support ticket with the same issue [CAS-40987-T7F7N0] we have responded to your query there.
    Please continue the thread there to avoid confusion.
    Anand
